Page 1 of 1
[ 4 posts ] |
Steering column Bolt at clamp......
48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
This bolt should pop out ....right ??
Bolt was tight, but is now turning in the clamp but will not come out, even with some hefty taps with a "persuader". Should I hit it harder or just cut it....?
| March 13th, 2020, 9:20 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1205 Location: Magyarország
 Re: Steering column Bolt at clamp......
| March 14th, 2020, 8:26 am |
Roger V
I'm not convinced cutting it is going to help you get it out. Try pulling the column up a smidgen.
| March 14th, 2020, 12:33 pm |
Taskos
Joined: February 22nd, 2012, 10:34 am Posts: 424 Location: Greece
Just make sure that the bolt is aligned with the slot on the steering shaft before you try the withdraw it. On refiting pay attention: The screw of the clip connecting the steering wheel and pinion in the engine compartment, has to be completely removed now (not only loosen the screw). When assembling the steering, those screw has to be tightened carefully!!!! The nut is a self locking model and the clip should not be disorted while fixing the nut, which could cause the cracking of the steering column!!!. Thanks to Walter, who has published an article at the German 2CV magazine Entenschnabel about that serious problem. http://www.entmontage.de/
| March 14th, 2020, 1:08 pm |
Page 1 of 1
[ 4 posts ] |
Users browsing this forum: No registered users and 220 guests |
