View unanswered posts | View active topics It is currently June 19th, 2026, 2:02 pm
 Stupid chassis question......
Post Stupid chassis question......
OK, I apologise in advance for a stupid question...... :roll:
I'm contemplating a chassis change rather than repair on my AZU250 van and assessing the size of the task, and the logistics, of carrying out the task in my height restricted, single garage, (and no driveway......)
Plan would be, to raise body as far as I can, (to the rafters), and roll out the chassis....
So, the question, is the body really only secured to the chassis by a few teeny bolts along the floor/chassis junction in the passenger compartment, then a couple of equally small nuts and bolts on the crossmembers under the load area??? Or am I not seeing something......
March 7th, 2020, 7:24 pm
Post Re: Stupid chassis question......
Yes, that's all and the steering column, wiring loom, gear lever, fuel line and brake lines have to be disconnected.
March 7th, 2020, 7:33 pm
Cheers !
(Engine and box are out just now along with handbrake, loom etc......)
March 7th, 2020, 7:36 pm
Couple of bolts at the end of the rear chassis rails as well - seem to remember you remove the fuel tank as well. Then the hydraulic tubes (or cut and replace with new ones)
March 7th, 2020, 8:05 pm
Thanks all !
March 9th, 2020, 6:54 pm
Don't know how much place you have, i have seen several times they put a van body on it's rear vertically. You have to take the doors and light off.
March 9th, 2020, 6:59 pm
Nahh, not enough space for that, I think I'll just get the rolling chassis out from underneath the body !
March 11th, 2020, 12:01 am
That is how we did it with our AZ.
We had four jacks and two long beams and supported the body with the beams sideways on the jacks.
If it is wide enough you can get the rolling chassis from under the body and park it there again when you are not working on the car.
https://flic.kr/p/w3BRDt
March 12th, 2020, 9:29 am
Yea, thats the plan.....4 tall axle stands should "just" be tall enough
March 12th, 2020, 5:29 pm
OK, decision made, new chassis ordered from Ken Hanna.....
Gonna be at least a month for delivery so plenty of time for me to get old chassis out and bits stripped, cleaned, replaced.
I'll clean and repair old chassis and store it away with the original engine/box....
Hopefully be out and about in the Summer.....
March 13th, 2020, 12:37 pm
Users browsing this forum: No registered users and 198 guests
