Page 1 of 1
[ 7 posts ] |
48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
 Brake pipes
I think I know the answer already, but just to confirm.....
1. When working on brake lines, (gearbox swap), the brake pipe seals should be replaced...?
2. Having always made up my own pipes on "normal" rebuilds, I understand that this is prob not practical on A-series due to the flaring tool needed being different to "normal".
Cheers Gerry
| February 17th, 2020, 11:44 am |
Roger V
 Re: Brake pipes
Front discs! Never really thought about making another pipe up! Tricky, as you suggest.
If I recall, the pipe seals are just a little rubbery (though not rubber) tube. Myself, after inspection, if I thought they would seal, I would re use them.
Not sure if there are different fluid types for discs. If so, its critical they are the correct ones.
If you have split the callipers, I would replace the little seal between the halves.
| February 17th, 2020, 12:18 pm |
48pop
 Re: Brake pipes
Planning on staying with drums, but different ratios  Seals are different for lhm and regular fluids....
| February 17th, 2020, 3:52 pm |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2304 Location: South-Limburg
 Re: Brake pipes
LHM ones have green stripe on them the others a red. If you use the wrong ones they can dissolve. But if they are not split and still flexible i do reuse them.
| February 17th, 2020, 5:58 pm |
Roco
Joined: November 7th, 2016, 6:23 pm Posts: 49 Location: In the depths of darkest Surrey
 Re: Brake pipes
48pop wrote: I think I know the answer already, but just to confirm.....
Cheers Gerry Hi guys , dont take chances on brakes , not only does your live depend on them , so does other peoples , the correct seals are still avaible, https://www.ecas2cvparts.co.uk/brake-pi ... -1300.html
| February 17th, 2020, 10:19 pm |
chevrons2
Joined: April 9th, 2010, 12:21 am Posts: 464 Location: West Sussex
 Re: Brake pipes
...but those are not the correct seals for drum brakes, (which is what 48pop is asking about the seals for). These are: https://www.ecas2cvparts.co.uk/brake-pi ... -1415.htmlThey usually re-seal ok but they're only 48p each, so for peace of mind, you might as well replace them.
| February 19th, 2020, 3:57 pm |
Roco
 Re: Brake pipes
chevrons2 wrote: ...but those are not the correct seals for drum brakes, (which is what 48pop is asking about the seals for). These are: https://www.ecas2cvparts.co.uk/brake-pi ... -1415.htmlThey usually re-seal ok but they're only 48p each, so for peace of mind, you might as well replace them. thanks for the correcion chevrons , i miss read the post, and thought it was about changing from drum to disk
| February 21st, 2020, 2:44 pm |
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 190 guests |
