View unanswered posts | View active topics It is currently May 15th, 2026, 10:21 am
Reply to topic  [ 372 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 38  Next
 Yellow Dyane
Post Re: Yellow Dyane
ImageP1020715 by Robndaisy, on Flickr
The little chariot awaits...
ImageP1020716 by Robndaisy, on Flickr
Meanwhile the engine is still soaking before stripdown. On the old van there were Banjos so little chance of wrecking the oil cooler, still, I might be lucky.
October 30th, 2019, 7:10 pm
You never know.
October 30th, 2019, 9:23 pm
Online
Galvanic corrosion is the enemy, as I'm sure you know. I had an issue with the oil cooler a few years ago, and I wasn't even trying to undo it!
October 30th, 2019, 9:51 pm
Online
Edit
Doh!
October 30th, 2019, 9:52 pm
Been said before ...
Oil cooler pipes can be repaired is 10mm compression fittings.
Crew fix COMPRESSION EQUAL COUPLER 10MM (37293)
October 30th, 2019, 10:00 pm
Plus 10mm copper tubing with brass olives soldered onto the new 'feet'... ;)
October 30th, 2019, 10:58 pm
Thanks lads! it's good to know there is a plan B :D .
October 31st, 2019, 10:26 am
My oilcooler was eaten away by 25 years of street salt. When i wanted to clean it with the pressure washer all the fins crumpled... I have now a painted version. But the bolts came loose without no trouble though...
October 31st, 2019, 9:29 pm
If the flamin' engine hadn't been seized by standing too long and not turned regularly, I probably wouldn't have started to strip it. I've only ever stripped/rebuilt that 425cc. The Ebay Dyane one is still in bits and the crankcases are corroded where it sat on the earth for ages.
ImageP1020298 by Robndaisy, on Flickr
Probably still ok to use, unlike the gearbox ;) , but I'll use the engine and box that came with the car and I need to learn how to put a 602cc. back together properly and if that means having to repair the oil cooler then that's part of that learning curve I reckon. :)
October 31st, 2019, 9:49 pm
If you re-use the oilcooler be shure to clean it well on the inside.
November 2nd, 2019, 4:16 pm
Users browsing this forum: Roger V and 295 guests
