Author |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1173 Location: Magyarország
 Re: Yellow Dyane
Roger V wrote: French fries! In the UK people call it french fries, in Holland the Belgiums are famous for their ˝frites˝. It is sold in so called ˝frites-kots ˝ where as ˝kots ˝also stands for throwing up after you are sick of too many frites . https://www.gastropedia.nl/wp-content/u ... ltuur2.jpg
August 12th, 2019, 8:47 am |
rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 877 Location: Rhayader Mid Wales
 Re: Yellow Dyane
Well, we've had a bit of rain over here but today was dry eventually  , P1020598 by Robndaisy, on Flickr another quality* job and all ready for the 100 metre hurdles  * all I could find laying about, nailed and some 8mm. studding, screws aren't suitable for this application are they  : .
August 17th, 2019, 8:32 pm |
Geert
 Re: Yellow Dyane
It could be more reliable with an extra support diagonal between the two legs , or legs and horizontal beam.
August 18th, 2019, 8:20 am |
rob massey55
 Re: Yellow Dyane
I'll put some more effort in then  , ready for this Saturday. I am much happier when working with metal, although even then, I have been known to grumble  .
August 19th, 2019, 7:09 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1634 Location: Exeter, Devon
 Re: Yellow Dyane
Yep, needs bracing.
August 19th, 2019, 10:40 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2248 Location: Near Monmouth
 Re: Yellow Dyane
Is a Dyane body that heavy
August 20th, 2019, 9:44 am |
 Re: Yellow Dyane
Nope, it isn't, so I'd have thought some knee bracing should be enough for Rob's frame. It doesn't need to be as pretty as these ones...  subarupete wrote: Is a Dyane body that heavy
August 20th, 2019, 2:13 pm |
rob massey55
 Re: Yellow Dyane
What's this ^^^ your new workshop  Had another look at the wooden trestles and rejected them, mustn't let my standards slip  . P1020602 by Robndaisy, on Flickr I should be able to knock something up out of these old Nature Reserve sign frames from work. I want to be able to 'flat pack' them after the Dyane is finished, maybe they could go to Portugal How's it said, "Dee-ane or Die-ane"
August 20th, 2019, 7:10 pm |
 Re: Yellow Dyane
Dye-anne?
August 20th, 2019, 10:34 pm |
rob massey55
 Re: Yellow Dyane
Ah yes, I forgot about the other pronunciation of 'Die'.
August 20th, 2019, 11:50 pm |
Users browsing this forum: No registered users and 25 guests |
