View unanswered posts | View active topics It is currently November 19th, 2025, 9:56 pm
Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 ICE.
willy wonka
Post Re: ICE.
i think you look more silly with a starting handle!!!!!!!!!!!!!!! hahaha
August 10th, 2009, 11:05 pm
Post Re: ICE.
alright i'll give you that one :oops: :lol:
Low and Loud!
August 10th, 2009, 11:09 pm
Post Re: ICE.
I like having a starting handle. Try starting some gash Fiesta or similar with a flat battery and no jump start...
August 10th, 2009, 11:14 pm
Post Re: ICE.
yeah but when it was fully drained it didn't work cause of lecy ign!! :roll:
Low and Loud!
August 10th, 2009, 11:17 pm
Post Re: ICE.
[quote="ken"]Hi folks,
just out of interest, isn't an amplifier rated on its 'music' power, not the current draw? From a little searching on the net, one site suggests that a 1000 watt amp would pull around 25amps from the car's electrical system.
Mind you, that still means it could be a good idea to carry a spare battery... ;)
im no electrician ken so i dont have the answer, if the music is really bassy, or constant, the sub will require more power, thus drawing it from the battery, mine seems to run pretty well with out a power cap atm so im not using it, though a second battery is a good idea... how would i go about charging it? would charging a second battery off the existing alternator burn it out??? i might just get one for show purposes then charge it at home...
August 13th, 2009, 9:42 pm
Post Re: ICE.
You can buy such a thing as a 'split charge system' but I've no idea how it works, other than it will charge 2 batteries from one alternator.
Maybe a search on eBay or a call to Andy Morris will do the trick?
August 13th, 2009, 10:59 pm
Post Re: ICE.
Managed to goad my dad into starting his new Series IIA Land Rover with the starting handle yesterday, just to see if he could. Now *that's* in car entertainment (I was sat in the driver's seat ;) )!
August 15th, 2009, 11:47 am
gym bunny
Post Re: ICE.
haha,
My van has an intrusive approx 127+dB stereo installed as seen at the WM! Kenwood MP3/cd headunit under dash with line in and out.
Front doors have Pioneer 17cm 2 ways plus sony 3/4" tweeters in the tops of them. Behind the front seats on a shelf are a pair of Caliber 6x9s currently running off the headunit as are the front door speakers. I have spare chanels on the Kenwood amp which runs the 12" kenwood sub currently. in the rear of the van are a pair of Infinity 6x9s and a pair of 4 way kenwood 6x9s both running off a JBL amp. Amp has line out for multi car hook up! I have the standard 2cv battery up front linked to an 85amp leisure battery in the back via a split charge relay. (100amp i think) this is all cabled in with some fat gauge cable (about 10mm if not fatter) and special 40amp fuses i think.
Next time I'm out in the garage I'll take some pics.
Dont forget with ice you need a laser or rope lights and a beacon!
1299cc FTW
August 17th, 2009, 9:26 pm
Post Re: ICE.
i got 2 beacons and a laser light im sorted!
August 20th, 2009, 7:52 pm
Post Re: ICE.
Pics Tim? I´m planning to take old Sony head unit out of my Xantia and put it to the Aca this winter. Then i just have to decide wich speakers i´m gonna use and amp, wich i do not have yet.
Pete.
Remember to smile!
August 24th, 2009, 3:19 pm
