View unanswered posts | View active topics It is currently November 19th, 2025, 8:21 am
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 84, 85, 86, 87, 88  Next
 1-2-spark
Post Re: 1-2-spark
Thanks Geo. Understand fully. We're thinking about what we might be able to do about this so enthusiasts can benefit whilst protecting your interests 100% so it can be developed even further if you feel like it.
If it was easy we'd already have an answer, so it might take a bit of time (plus whatever time it takes for 65 cars and interested parties to get back from raid 2016 australia, and start making sense).
RAID 2016 is underway! See http://www.2cv.com.au/forumdisplay.php/ ... ralia-2016 and just accept the site will always be way out of date because most of the RAID route is nowhere near mobile wifi to give updates.
August 5th, 2016, 1:26 pm
Post Re: 1-2-spark
Modern meets Old :D
Just brilliant.
Thanks Geo
August 7th, 2016, 11:44 am
Post Re: 1-2-spark
So a probably costumer wants to have coil on plugs in his 2cv and if I could realize this with 1-2-Spark.. So I wanted to now myself by ordered two pencil coils which are directtly mounted on top of the plug.. So no coil-leads are neccecary annymore so less can go wrong..
This evening I put a little testbench together and made the rpm raising from about 150rpm all the way up to around 9000rpm...
Creating a lot of ozon in my livingroom :D :D :D :D
so pump up the volume and watch the video...
https://www.youtube.com/watch?v=NdRgDT4 ... e=youtu.be
July 18th, 2019, 9:35 pm
Post Re: 1-2-spark
Like it.
Is it an "add-on" to the existing board or brand new PCB.
Perhaps use these
https://www.ebay.co.uk/itm/Ignition-Coi ... SwVQBdA1II
July 19th, 2019, 8:41 am
Post Re: 1-2-spark
No you csn use them insted of the 2cv coil. However you need probably another coil driver because you have 2 coils now. When I,m back from Croatia I will test it in my car.. your Jaguar coil is a good fing by the way..
I have the dwell time reduced to 1000 over the whole range..
July 19th, 2019, 11:11 pm
Post Re: 1-2-spark
I have some VAG smart COP for when I eventually get my speeduino installed. :roll:
July 20th, 2019, 11:32 am
Post Re: 1-2-spark
So tonight I had some spare time so I installed the coil on plugs in my Ami.
I just pluged them onto my plugs, no brackets yet and hey it works.. It feels like the engine runs slightly better/nicer with the new coils.. So I'm going to make 2 brackets this week and then have a test drive..
I guess I will never use coil-leads anymore...
Anyone seen a 2cv running without coil leads... take a look at the video..
https://youtu.be/41zNy0oRHbk
Tomorow I will put the car outside in the sun and make another video so that you have a better view..
August 20th, 2019, 11:04 pm
Post Re: 1-2-spark
that's Witchcraft 8-)
August 20th, 2019, 11:55 pm
Post Re: 1-2-spark
Almost...
August 21st, 2019, 6:23 am
Post Re: 1-2-spark
Brilliant,
Which COP units?
Any modifications to the 1-2-Spark control unit?
August 21st, 2019, 8:02 am
