View unanswered posts | View active topics It is currently August 15th, 2025, 6:32 am
Reply to topic  [ 964 posts ]  Go to page Previous  1 ... 38, 39, 40, 41, 42, 43, 44 ... 97  Next
 AZL 1957
Post Re: AZL 1957
Yep the AZ(Luxe) the luxe was 2 horns, aluminium trim on bonnet and door sills, and on the doors.... very luxe... ;-) And an wider rear window i thought.
April 23rd, 2019, 10:31 pm
Post Re: AZL 1957
Here another 2cv i cut out off a bramblebush in 1988. Geo knows it too. it was later put in an barn but i don't know if it's still there...
May 8th, 2019, 9:51 pm
Online
Post Re: AZL 1957
Mind the bonnet !
May 9th, 2019, 7:36 am
Post Re: AZL 1957
it's rather solid if you stay near the hinge...
May 9th, 2019, 5:12 pm
Post Re: AZL 1957
Some bastard parked into my grille and took off. :evil: :evil:
June 6th, 2019, 4:44 pm
Post Re: AZL 1957
That's bad luck but, because it's metal, you can carefully fix it, unlike the modern plastic sh*t.
June 6th, 2019, 6:13 pm
Post Re: AZL 1957
After i took the inside mesh off, i could push it back and to do a bit of work with the undenting set. Some paint flaked off and two half chevrons broke their fixing lugs...
June 6th, 2019, 8:22 pm
Post Re: AZL 1957
The dent is flattend but the bonnet seems to be tordated. One side scratches on the wing the other side i can put an hand between....
Here the repaired chevron halves, with new lugs glued on with 2K.
June 7th, 2019, 8:53 pm
Post Re: AZL 1957
Did take the lot apart again yesterday. Slightly bend the bonnet in diverse directions, take an wing off, loosened the bumper and moved that a bit forward. Bend the bonnet catch. Put everything back together and no more scratching sounds while driving. pff. Still to do put one broken twice chevron-half back in, than the wire mesh and the aluminium grille surround. And if have to get some paint to retouch the grille.
June 10th, 2019, 9:00 pm
Post Re: AZL 1957
Thanks for making this nice thread.
Personally I avoid parking places where the cars are standing in a line. Because I think of other drivers like raving lunatics with no skills in car handling.
I prefer those parking spots where the cars stand parallel to each others. I believe the chance of getting away from that unharmed is better.
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
June 11th, 2019, 7:40 am
