View unanswered posts | View active topics It is currently June 19th, 2026, 5:02 am
Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
 Brake Fluid Leak
Post Re: Brake Fluid Leak
Thanks everyone. I'll give it a try in daylight tomorrow.
I rather think that we are at cross purposes using the word "bayonet". To me it's those two pins on the side of a light-bulb.
Dennis usually in the Cantal
1982 Red Special - RHD
March 13th, 2019, 9:23 pm
maybe better visible here, no bayonet, just a rim that clicks in the rubber seals.
March 14th, 2019, 9:08 am
From my experience, they tend to leak when cold, even with quite new seals. Never bothered to worry about, only check the amount of LHM more often on winters...
And another thing, they seems to leak more when not driving...
March 14th, 2019, 11:11 am
Thanks very much everyone. I pulled it out, carefully but firmly, if that makes sense.
The seals look OK but the reservoir has a crack, which was in a place where I couldn't see it until I took it off and started cleaning away the dirt.
I've ordered a new reservoir and new seals.
And no, that's not what I'd call a bayonet fitting (pins and a twist). It just pushes on .... and off. But then, actual bayonets stopped having bayonet fittings a long time ago.
March 14th, 2019, 12:29 pm
No pins on these bayonet fittings, nor on such fittings so described by many other manufacturers... ;)
https://www.sipuk.co.uk/connectors-coup ... ptors.html
March 14th, 2019, 4:03 pm
Other suppliers seem to have different names for those types of air line connectors, Ken:
https://uk.rs-online.com/web/c/pneumatics-hydraulics-power-transmission/pneumatic-adaptors-fittings-couplings/pneumatic-quick-connect-couplings/
And then, of course, Wikipedia speaks (twice):
https://en.m.wikipedia.org/wiki/Bayonet_mount
https://en.wikipedia.org/wiki/Bayonet_mount
March 15th, 2019, 12:25 am
'Bad' becomes good, 'wicked' becomes cool, 'cool' becomes great, now bayonet becomes push fit, and twist becomes tilt. Always been a push and twist action to me using pins into right angled slots or grooves.
Like fast cars - some things I don't want to keep up with.
Got the grumps this-morning.
March 15th, 2019, 11:24 am
I have had the same problem and agree with the comments. Leaks more in the cold, also when not used for a few days (especially in the cold weather). I've replaced the seals but the level is still going down slowly. Didn't notice any cracks in the reservoir. I'm just wondering if I've got the reservoir fully home. Does it need quite a lot of pressure to get the rims of the reservoir to engage in the grooves in the seals?
Don
March 16th, 2019, 12:06 pm
Don,
having carried out removal and refitting of master cylinder reservoirs on several hundred occasions during the last 35 years, this is what's worked for me.
( Click on the link for full text.)
In addition to using LHM as a lubricant, a light coating of grease on the seals and the reservoir spigots also helps to ensure an easy and leak-free installation... ;)
ImageDual master cylinder, bayonet fitting. by slcchassis, on Flickr
March 16th, 2019, 1:01 pm
Judging from the photo, it's not 'Grim up North' at all. :mrgreen:
March 16th, 2019, 1:43 pm
Users browsing this forum: No registered users and 229 guests
