AZL57
 Re: AZL 1957
From the broken gearbox i will only use the brakes i think. The rest will be spareparts.
| January 9th, 2019, 5:45 pm |
rob massey55
 Re: AZL 1957
You can't have too many spares
| January 9th, 2019, 10:13 pm |
AZL57
 Re: AZL 1957
Yes you are right. I have a lot but some parts are rare, like this centrifugal clutch gearboxes. Did again some cleaning, took the clutch of and one brake drum. The other drum didn't come off. I put some penetrating oil on it. Will try again later.
| January 9th, 2019, 10:48 pm |
AZL57
 Re: AZL 1957
At last i got the blocked brake drum off. So everything could be cleaned and the brakes replaced. But all this fiddly work took me again 3 hours. Opened the box to check the inside. Looked ok but all was rather black with old oil. So after replacing that i will do this again later to get the interior a bit cleaner. Have still to weld the exhaust which had an broken hanger than all can be reassembled and put back in the car.
| January 12th, 2019, 5:45 pm |
AZL57
 Re: AZL 1957
For all my trouble i collapsed at the chip shop and was brought to the hospital...
| January 13th, 2019, 12:37 am |
lpgo
 Re: AZL 1957
"Beterschap"... get well soon… and take it easy..
| January 13th, 2019, 12:43 am |
Roger V
 Re: AZL 1957
Bloody hell! What are putting in the chips!
| January 13th, 2019, 1:12 am |
Geert
 Re: AZL 1957
Fer, get well soon and take it easy.
| January 13th, 2019, 8:56 am |
AZL57
 Re: AZL 1957
Thank you guys. Feeling better now.
| January 13th, 2019, 11:42 am |
rob massey55
 Re: AZL 1957
Good!
| January 13th, 2019, 12:13 pm |
