Roger V
 Re: My Beduino
Thanks Ken Is there a rational as to why its better than both at tdc?
| November 15th, 2018, 7:38 pm |
Roger V
 Re: My Beduino
A bit of progress.  Set the tappets a bit lose. Compression is down a bit on one side. About 135/160. Squirting WD40 in the bore brings the compress up a little, so probably the bore/rings. However, engine has been stood along time, so watch this space. Yesterday, I got the shed off the ramps and blocks. Drove it out and back in to barn. Ta da
| November 22nd, 2018, 7:41 pm |
Roger V
 Re: My Beduino
Yesterday, it rained, and then it rained some more! Friday, I thought I would connect up and tidy some wiring. I really have little idea what connects to what in this bespoke harness! I removed all the dash and stereo etc to get a better view. I think today (no rain), I will remove the steering wheel for better access. Also think I will write a list of items that need to work and separate out the different systems. I also have an ammeter and cable that could install.
| November 25th, 2018, 12:46 pm |
Roger V
 Re: My Beduino
Wiring is done, but still some loom tape to apply. My mate in the farm had mentioned he had run out logs in the house, so I loaded up the the Bedouin and half filled his fire place when he was at work. Bedouin hardly noticed they were there.
| January 8th, 2019, 8:02 pm |
samfieldhouse
 Re: My Beduino
Avoid using electricians tape to wrap everything up. It goes horrible and if you need to get into the loom its just a big sticky mess.
I used small cable ties every 2-3".
| January 9th, 2019, 8:05 pm |
Roger V
 Re: My Beduino
Thanks Sam Your right, that's why I bought proper loom tape. It so much better as well.
| January 9th, 2019, 9:48 pm |
samfieldhouse
 Re: My Beduino
I didn't know that was a thing! Thanks!
| January 9th, 2019, 10:33 pm |
Roger V
 Re: My Beduino
| January 10th, 2019, 12:50 am |
Geert
 Re: My Beduino
I used that , works very well !
| January 10th, 2019, 10:13 am |
Roger V
 Re: My Beduino
Started on the bonnet today. The gap at the front is where I removed a rotten piece of wood. I've cut some wood to size and will let the glue dry over night. I may end up shortening the bonnet a little to get a tidier edge. When done, I'll fix the bonnet to the wings and create a tipping front end.
File comment: Bonnet needs attention :-)
| January 12th, 2019, 12:57 am |
Users browsing this forum: No registered users and 313 guests |
