AZL57
 Re: AZL 1957
| October 26th, 2018, 5:46 pm |
AZL57
 Re: AZL 1957
Today i had to replace a lightbulb in my mothers citroen c3. It took me more time than taking the engine out of the 2cv....stupid modern cars....
| October 27th, 2018, 3:23 pm |
AZL57
 Re: AZL 1957
The 57 started cutting out on accelleration, so the tank must be almost empty. So drove of the road and put 5 liters in. It started but then the idle was gone. I think the almost empty tank drew rubbish in to the carb. So i took the idle jet out to clean it. Than vroom, all start working again.
| November 8th, 2018, 6:21 pm |
Roger V
 Re: AZL 1957
I don't understand why dirt will only get pulled up from tank when the level is low?
| November 8th, 2018, 6:39 pm |
 Re: AZL 1957
Considering that the fuel pickup tube is almost at the bottom of the tank, I'd reckon it's an old wives' tale...  Or maybe it's a hangover from motorcycling days, when the 'reserve' tap was fed from a tube sited lower in the bike's tank than the normal inlet? Roger V wrote: I don't understand why dirt will only get pulled up from tank when the level is low?
| November 8th, 2018, 7:33 pm |
Roger V
 Re: AZL 1957
I would agree Ken. The only difference I can think of, is the fuel may move around more as the level drops, and lift sediment. Anyways, AZL, glad you sorted it.
| November 8th, 2018, 8:37 pm |
 Re: AZL 1957
Although nothing that an in-line paper element filter won't catch? Roger V wrote: I would agree Ken. The only difference I can think of, is the fuel may move around more as the level drops, and lift sediment. Anyways, AZL, glad you sorted it.
| November 8th, 2018, 10:55 pm |
Geert
 Re: AZL 1957
ken wrote: Although nothing that an in-line paper element filter won't catch? Roger V wrote: I would agree Ken. The only difference I can think of, is the fuel may move around more as the level drops, and lift sediment. Anyways, AZL, glad you sorted it.  Why do I have to clean my carburetor every 5 or 6 months or so? There is always some sediment in it, every time I open it. Despite an extra filter in the fuel line.
| November 9th, 2018, 9:41 am |
Roger V
 Re: AZL 1957
A metal tank I would guess.
Rust from the tank I suspect. Particles to small for the filter to stop.
Does the filter look like its capturing anything when you clean your carburetor?
| November 9th, 2018, 10:26 am |
lpgo
 Re: AZL 1957
I'm happely driving on Lpg.. for more then 25 years now.. The last 10 years on Lpg vapour injection, no problems here..
| November 9th, 2018, 1:22 pm |
Users browsing this forum: No registered users and 333 guests |
