View unanswered posts | View active topics It is currently June 19th, 2026, 10:50 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 85, 86, 87, 88, 89, 90, 91 ... 105  Next
 Make Your Own ....2CV.... 4x4
Looking more like a 2CV
However after many precision measurements, the 7mm bolts for the body floor are out by 10MM!!!!
Reason is support strut is hard up against the bulk head.
September 29th, 2018, 11:05 am
Well that's in the ballpark considering :) .
September 29th, 2018, 1:34 pm
Made the most of the sunshine...
https://youtu.be/q7-rgRi-4G0
September 29th, 2018, 2:47 pm
Bit of a problem re Accelerator Pedal (COCK-UP)
May be able to Crank them enough to the left???
October 2nd, 2018, 11:55 am
Make a RHD out of it.. It will solve your problem..
October 2nd, 2018, 12:19 pm
How about and accelerator on the steering wheel, or is that not advisable for off road?
October 2nd, 2018, 1:21 pm
Did have thoughts about that but my old brain would need to retrain.
The shell was RHD and I changed it!.
Bit of progress , welded/modded the brake pedal, offset is now 30mm.
The gas pedal I can maybe able to bend?
October 2nd, 2018, 2:13 pm
Yes. Also brake pedal can be bent, as I did on my 4x4 Dyane, needed some cleaeance to my foot, so it was possible to use accelerator without hitting brakes simultaneously...
October 2nd, 2018, 7:13 pm
Before and After.
Need to make a Tunnel for the prop-shaft, that will take up some space but it should work.
October 3rd, 2018, 4:46 pm
subarupete wrote:
Before and After.
Don't worry about a propshaft tunnel, just keep your shoelaces tied up! Nothing wrong with having a car which might eat you alive, it just keeps you on your game, thats why we love 2cv's right!? 8-)
October 5th, 2018, 10:03 pm
Users browsing this forum: No registered users and 67 guests
