View unanswered posts | View active topics It is currently June 19th, 2026, 10:17 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 84, 85, 86, 87, 88, 89, 90 ... 105  Next
 Make Your Own ....2CV.... 4x4
Rear Diff now rotates in the correct direction!
Fitted in chassis ... now just a few bolts, pipes, drive shafts and prop shaft to attach.
September 10th, 2018, 11:56 am
Rear End.
Transfer Box and shafts
September 15th, 2018, 10:41 am
Short Video
https://youtu.be/MsEvlHG4clU
September 15th, 2018, 12:36 pm
What a beast 8-) .
September 15th, 2018, 2:33 pm
Amazing...
Wish I could figure what each component does, have to admit that spare driveshaft threw me for 'about' 1 second. :lol:
September 16th, 2018, 11:19 am
The spare drive shaft is to drive an additional cooling fan like Porsche 917 ;)
September 16th, 2018, 11:33 am
https://www.google.com/search?q=porsche ... hH6l3db32M:
Yes I can see the evolution :) .
September 16th, 2018, 12:50 pm
Rear Disc Brakes Line Lock.
Allows the rear brakes to be locked on as a pair or individually.
Push the brake pedal and switch the valves closed, remove foot from pedal, Rear bakes held on.
Adapted from Citroen Xantia ABS unit.
September 20th, 2018, 2:03 pm
Front Struts Plumbing.
Used Brass (Imperial Size) compression to connect the pipes, hope they withstand the 62Bar.
This time, plan on only having one pump for both the front and rear struts.
September 21st, 2018, 3:14 pm
Body meets Chassis !!
September 28th, 2018, 2:50 pm
