View unanswered posts | View active topics It is currently June 19th, 2026, 11:56 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 82, 83, 84, 85, 86, 87, 88 ... 105  Next
 Make Your Own ....2CV.... 4x4
Online
Not that many days and its going to be very cold next week:)
February 22nd, 2018, 8:57 pm
10mm.'s better than nowt! now the workshop's spotless, Crack on 8-) .
subarupete wrote:
Ooh clean floor!.
Fitted the front diff prop shafts, they fit but very tight near the gearbox about 10mm clearance.
February 22nd, 2018, 8:59 pm
Online
Unexpected problems do occur or is it bad planning:)
The input shaft to the remote gearbox had some play, had a look at the seal found it was a bad condition.
Chevronics do a seal (££££) for GS/GSA boxes but the LN is about 1.5mm larger!
So a bit of milling it was substituted sealed bearing.
We will have to see if its OK.
Input Shaft.
Old Seal.
New Bearing in place.
February 23rd, 2018, 7:33 pm
Online
The list of things to do, should get shorter.
However it seems that the plan to use a standard exhaust with cross-box wont fit:(
Bigger calipers + the rear plate of the diff gets in the way.
Plan to fabricate an exhaust from mandrel bends...2 into 1 very sporty?
Red lines show the plan, but as we are all very aware "Red Lines" can change or even disappear!!!
February 26th, 2018, 2:52 pm
Online
Can't make the exhaust till the body is sitting on the chassis and can't do that until I have a transfer shaft fitted.
What is required, "the middle part".
But, not happy with getting it welded.
So have to machine one!!
Purchased a bit of steel..
Some difficult milling/turning/drilling and lot of Google.
Bit of a challenge but nothing ventured.....
March 18th, 2018, 11:03 am
Did you go to Morvan??
April 8th, 2018, 11:19 pm
Online
Nope, the car was not finished:(
April 9th, 2018, 8:31 am
Online
Hi all,
Back again after a long period of no work on the off-road car or the road car.
Turning & Milling required to join the two uj's to make the shaft between the clutch shaft and the remote gearbox.
August 2nd, 2018, 10:11 am
Good to see you back on it Pete :D .
August 2nd, 2018, 10:14 pm
Yep +1 :)
August 2nd, 2018, 10:52 pm
Users browsing this forum: No registered users and 67 guests
