Page 1 of 1
[ 7 posts ] |
northyorkspaul
 Tappets Again...
Hi ok so I know this has been covered at length before but just wondered if anyone has any thoughts on this...I have set my tappets to .20 all valves...done it correctly...now n/s is quiet but o/s has a definate tap why??
Have double checked again and same...any thoughts?...ta.
| July 23rd, 2018, 11:03 pm |
bobh
 Re: Tappets Again...
Somewhere in the chain there are worn parts, cam,cam follower, pushrod, rocker etc. Its more difficult, but adjust the tappet with the engine ticking over - get ready to catch some oil ! BobH
| July 24th, 2018, 7:32 am |
Derek
This is not advisable. 1 The tappets should be checked with engine cold. 2 With engine running and a feeler gauge inserted to the required gap, there will be insufficient closure of the valve and the hammering to the feeler gauge could damage the blade giving a false reading - if you could actually manage to adjust same with the rockers on the move.
| July 24th, 2018, 7:43 am |
Roger V
Ensure you are pushing with the screwdriver when adjusting. It is probably wear though. Or .... Is the quite side to quite!
| July 24th, 2018, 9:58 am |
Derek
Roger V wrote: (snip) Or .... Is the quite side to quite!  I think you mean - quiet side is too quiet?
| July 24th, 2018, 11:17 am |
Roger V
Well, that would be a combination of auto correct and a need to go to Spec Savers.
| July 24th, 2018, 11:37 am |
northyorkspaul
Thanks chaps,must be bit of wear some where then, strange on one side only!..Well it's not too bad so will leave it.Forgot to mention I have had the heads off because plug stripped so ground valves while off but all back OK..Can't remember what the tappets were like before unfortunately as it's nearly three years since it was running .Thanks again.
| July 24th, 2018, 1:18 pm |
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 227 guests |
