View unanswered posts | View active topics It is currently July 5th, 2025, 7:30 am
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 41, 42, 43, 44, 45, 46, 47 ... 78  Next
 Van repairs
Post Re: Van repairs
Hope you're all enjoying the World Cup as much as I am, despite this Summer Cold I've managed to pick up...nobody knows the suffering I'm going through :roll:
ImageP1010978 by Robndaisy, on Flickr
ImageP1010979 by Robndaisy, on Flickr
The exhaust is designed to kill the driver and passenger, surely :o . This should help.
ImageP1010984 by Robndaisy, on Flickr
Old Choke cable inner wire corroded and won't reach the carb. lever. Bought some piano wire to fix it.
ImageP1010985 by Robndaisy, on Flickr
Removed the swaged wire and drilled deeper.
ImageP1010988 by Robndaisy, on Flickr
All set for Silver Soldering. Which worked well.
ImageP1010991 by Robndaisy, on Flickr
The outer is too short as well, I've pulled it into the carb. but that's no good.
I could warm up the outer and stretch it a bit
Or cut the outer in a suitable place and push each end into some fuel pipe to take the tension off it
Or(preferred option) keep drinking medicinal Gin and watch more football 8-) .
What does the Forum think :?: :?: :)
June 17th, 2018, 8:42 pm
Online
Well ok then, but only if I can have some cider!
June 17th, 2018, 9:07 pm
ImageP1010993 by Robndaisy, on Flickr
Perfect day for some paint, Holts, which was £2.00 a can on offer, no idea what shade of grey it is, should be AC 132.
June 22nd, 2018, 10:21 pm
Online
Fifty shades of grey! .... Steady there :lol:
June 23rd, 2018, 12:28 am
You'd best get back to your virtual welding :lol:
June 23rd, 2018, 7:53 am
Online
I like to think ...
'It's almost, but not entirely, unlike welding'
Any one know who/what I am paraphrasing?
June 23rd, 2018, 11:11 pm
got a few jobs done today, wrapped the loom, bled the brakes(with a helper this time) and began looking at the tracking. Had put the track rods to the lever arms with the same cups, springs and shims in the order they were before. now the van is on the floor, one of the front wheels is way off straight ahead.
If I disconnect the rods, turn the steering wheel to full lock, mark it's position, turn it all the other way and back half the amount of turns(then secure it) that should be set right for further adjustment and correction...shouldn't it :?: :)
Had previously fitted the wheels to the hubs and spun them to see if they are true and they are ok.
June 23rd, 2018, 11:44 pm
Read the book now, no mark engraved on the plate on the front of the steering crossmember so have aligned fronts with string line. Time to fiddle with the shims.
June 24th, 2018, 12:51 pm
If the exhaust is mounted ok you won't have fumes in the cab. It can happen if you are standing stil but on driving it's ok. The exhaust end should protrude a bit under the chassis and the "louvres" in the chassis should be open. They are sometimes bend in by jacking the car with a block of wood under the chassis.
June 24th, 2018, 3:59 pm
Yeah they were, but I've opened 'em up :) .
ImageP1010994 by Robndaisy, on Flickr
ImageP1010995 by Robndaisy, on Flickr
I need this for the MOT.
June 24th, 2018, 10:51 pm
