Page 1 of 1
[ 10 posts ] |
No dash lights and valve clearance procedure
Two Chevrons
Joined: August 17th, 2010, 11:47 pm Posts: 194 Location: Chichester West Sussex
I originally had dash lights, for some reason now I have none! All other electrics work fine, the three fuses on the firewall are all ok , a) are the bulbs easy to get at/change and check voltage at terminals? B) I can say it was possibly post welding this occurred and no I didn’t disconnect the battery beforehand, could I have blown all the bulbs on the display? B) when checking valve gaps do I say start with the inlets on one cylinder make sure the valve is fully open then on the other cylinder check the inlet and set then follow for exhaust? I have read that another bloke does it on dump as in both valves compressed on one side the the open valve on the other cylinder set and rotate until the other valve on the same side is fully open and then set and the do the same for the opposite cylinder. Only just set the in to .20mm and the ex to .25mm but it sounds like a skeleton in a dustbin having a wank now. Could it be I need to take the bean cans and check AGAIN please god no... many thanks for your help in advance half the carb farts seem to have stopped so many thanks indeed
_________________ 1972 dyane4 435cc
| June 8th, 2018, 7:28 pm |
bobh
 Re: No dash lights and valve clearance procedure
Why not have a look at the detailed description a couple of posts above yours - "Setting Valve Clearance". It would seem a good place to start !
As to dash lamps - Can't help there. Hope you didn't blow up the alternator controller when welding and now its outputting too high a voltage !!!
| June 8th, 2018, 8:01 pm |
Two Chevrons
bobh wrote: Why not have a look at the detailed description a couple of posts above yours - "Setting Valve Clearance". It would seem a good place to start !
As to dash lamps - Can't help there. Hope you didn't blow up the alternator controller when welding and now its outputting too high a voltage !!! Set as that thread, charging at 14.6 volts at the battery terminals
| June 8th, 2018, 9:31 pm |
Roger V
Not sure what you mean by dash lights! Try looking at your fuses again and ensure they are making good contact. I tend to do both tappets on the compression stroke on one side, and then do the other side. Not saying it right or wrong, its just what I do.
| June 9th, 2018, 7:59 am |
Derek
"I tend to do both tappets on the compression stroke on one side, and then do the other side. Not saying it right or wrong, its just what I do"
That's how I have always done them too, near the top of compression on each side.
Always disconnect battery and alternator prior to welding.
| June 9th, 2018, 8:17 am |
Two Chevrons
Roger V wrote: Not sure what you mean by dash lights! Try looking at your fuses again and ensure they are making good contact. I tend to do both tappets on the compression stroke on one side, and then do the other side. Not saying it right or wrong, its just what I do.  I had a quieter engine going it that way but my engine did not seem to give consistent readings when re checked.. I mean lights around instruments so I can read the speedo etc at night
| June 9th, 2018, 10:20 pm |
Roger V
I push on the tappet adjuster with a reasonably firm pressure on the screwdriver to try and remove slack from the pushrods etc. Then I turn it over on the starting handle and check them again.
| June 9th, 2018, 11:01 pm |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2289 Location: South-Limburg
My dash lights are getting worse too, or the bulbholder is sliding out of it's housing or the blub is getting burned black. It's 35 years old now. You can reauch them without disassembling the dash by taking out the battery and its tray. Then you can reach in behind the dash. It's not that much space but it works.
| June 25th, 2018, 7:48 am |
chevrons2
Joined: April 9th, 2010, 12:21 am Posts: 464 Location: West Sussex
AZL57 wrote: .....You can reach them without disassembling the dash by taking out the battery and its tray. Then you can reach in behind the dash. It's not that much space but it works. That's true on a LHD 2cv but TwoChevrons has a Dyane. On a Dyane, if you get a mirror to look down the gap in front of the bottom of the speedo, you can see the little rectangular lens over the bulb that illuminates the speedo. You can just pull that up and it will bring the bulb with it. Putting it back in is a bit more fiddly, so the mirror will help.
| June 25th, 2018, 10:55 am |
AZL57
Ah yes you are right, the dyane is a lot easier about the dash lamp..
| June 25th, 2018, 5:38 pm |
Page 1 of 1
[ 10 posts ] |
Users browsing this forum: No registered users and 63 guests |
