View unanswered posts | View active topics It is currently May 7th, 2026, 10:39 am
Reply to topic  [ 417 posts ]  Go to page Previous  1 ... 37, 38, 39, 40, 41, 42  Next
 1976 AZU250
Post Re: 1976 AZU250
Thanks for your replies. I'll have a go with the soldering iron.
One other question: should the float move up and down freely? The one on my gauge seems rather stiff.
May 1st, 2018, 7:24 pm
Put some petrol on it and see if that frees it. :)
May 1st, 2018, 7:36 pm
The part where the contact slides up and down inside might be a bit oxydized after a long period of non use i had that too.
May 1st, 2018, 8:13 pm
Smiffy,
the 'wiper' which moves over the windings of the rheostat may be worn, as in the photograph below.
A repair can be carried out with a blob of solder, as long as it's not too late and it's damaged the windings...
Image'Wiper' in fuel tank rheostat, before... by slcchassis, on Flickr
May 2nd, 2018, 4:45 pm
Thanks for that tip, Ken.
Checked the "wiper" and it looks fine.
Soldered the broken strip. Job's a goodun!
May 3rd, 2018, 7:38 pm
Started tidying up the van's metal petrol tank today. The fuel gauge looks OK, but the inside of the tank looks a bit rusty above the halfway point.
Is there a way to de-rust the tank's insides?
June 3rd, 2018, 8:46 pm
Probably, if there is flakey stuff inside, chuck some nuts in(count 'em in and out ;) ) and cocktail shake it, rinse and fit an in line fuel filter. :) .
June 3rd, 2018, 10:03 pm
How detrimental would it be to shake some sharp sand around inside!
June 3rd, 2018, 11:54 pm
https://www.wickes.co.uk/Wickes-Sharp-S ... g/p/220112
you're on a commission aren't you ;) .
June 4th, 2018, 8:40 pm
Well, you have to admit, it is a bargain. :lol:
Anyway, can't stop, I'm off to Wicked. ;)
June 4th, 2018, 9:00 pm
Users browsing this forum: No registered users and 262 guests
