View unanswered posts | View active topics It is currently August 15th, 2025, 12:18 am
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 26, 27, 28, 29, 30, 31, 32 ... 78  Next
 Van repairs
Post Re: Van repairs
It will be when these are fitted :) .
ImageP1010673 by Robndaisy, on Flickr
Have been thwarted by the flamin' cold and snowy weather, dragged meself away from the woodstove long enough to clean and test this.
ImageP1010664 by Robndaisy, on Flickr
It works fine. There should be two horns on this old timer, what does the other one look like and is it deeper in tone?
March 5th, 2018, 8:16 pm
The other looks like a horn and sounds softer.
Does your horn/light switch have double contacts?
March 5th, 2018, 8:45 pm
Aah! Yes it does. Town and Country eh?
March 5th, 2018, 9:15 pm
Yes exact. The horn shaped one is on the first contact, if you push the button further the second horn cuts in. Nice noisy... :mrgreen:
March 5th, 2018, 11:08 pm
Ordered a new accelerator pedal and mounting bracket,
ImageP1010682 by Robndaisy, on Flickr
before I hang myself from the engine sling chains, how in Flame do these go together and work?
March 10th, 2018, 5:29 pm
I think they are different generation. The old pedal is put in flat on the floor pointing direction seat. Hooked in and moved forward. Then the rubber is clicked on to the accellerator rod. See this pic don't pay attention to the arrow. You can try and replicate this or find a 60s pedal...
March 10th, 2018, 5:50 pm
Cheers Fer,
ImageP1010685 by Robndaisy, on Flickr
The old floor was still there when I got the van but had rusted out and the previous owner had made two inserts and pop riveted them in over what was left. He then popped a piece of hinge onto the bottom of the pedal and onto the chassis. Fair enough, I'll see if I can get it back to how it should be ;) .
March 10th, 2018, 7:33 pm
It's an interesting repair too. ;-) The pedal hinge is the same type like those of the doors and bonnet.
March 10th, 2018, 10:52 pm
Imagepage_126 by Robndaisy, on Flickr
Pssst! what diameter do you think the mirror is?
I can get this,
Image0806L-2__3000001__ by Robndaisy, on Flickr
but it's 145mm. diameter, too big eh? They do an oval one too, 110x82.
March 19th, 2018, 10:45 pm
Maybe these guys https://www.franzose.de/en/Citroen-2CV/ ... iff=mirror
March 20th, 2018, 11:01 am
