View unanswered posts | View active topics It is currently June 19th, 2026, 12:56 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 81, 82, 83, 84, 85, 86, 87 ... 105  Next
 Make Your Own ....2CV.... 4x4
Online
Discs now fitted and different brace (x2) allows drive shaft clearance.
Whoopee, only two oil leaks.
Need a copper washer under the sump nut.
And a seal?? for the splined prop shaft flange??
February 9th, 2018, 12:54 pm
Great job you did then...
February 9th, 2018, 2:16 pm
On Land-Rover there is felt under the nut at flange. And many put also some sealing/glue to splines to avoid leaking...
Nicely done when there isn't any other leaks..!
February 9th, 2018, 3:04 pm
Online
Thanks guys.
February 9th, 2018, 3:51 pm
Part no 5 on that picture...
February 9th, 2018, 4:05 pm
Online
Something like this...
Perhaps make it from felt or soft rubber?
February 9th, 2018, 5:08 pm
Online
Fitted the centre bearing for the front prop shafts.
Shortened the first of two prop shafts, combination of suzuki/truimph-herald bits.
February 15th, 2018, 5:15 pm
Online
The first on and even painted it...
February 17th, 2018, 4:58 pm
Online
Ooh clean floor!.
Fitted the front diff prop shafts, they fit but very tight near the gearbox about 10mm clearance.
February 22nd, 2018, 5:17 pm
Only 5 weeks to Morvan.... you should hurry....
February 22nd, 2018, 8:04 pm
