View unanswered posts | View active topics It is currently June 29th, 2025, 12:26 am
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 78  Next
 Van repairs
Post Re: Van repairs
I thought you needed empty beercans ! :)
January 20th, 2018, 10:39 pm
:mrgreen:
Took the other head off, which in my world involves removing the rocker gear shafts with heat, tested the tubes, ok, re-assembled the engine, ran it up, leakfree...for now, thanks everyone. Ken if you'd like the rods, let me know your address and I'll pop 'em in the post :) .
January 21st, 2018, 8:11 pm
Sound easy enough, hope the engine will stay leak free after your repair.
It is a good tip for anyone who will come across the same problem in future .
Thanks for sharing your experience .
I like the way you rebuilt your van.Very inspiring .
January 21st, 2018, 11:29 pm
ImageP1010570 by Robndaisy, on Flickr
Drawing inspiration from the Apollo 13 rocket scientists, from 'leaf blower' exhaust to old vacuum pipe via a baked bean tin.
Dynamo is producing volts.
January 24th, 2018, 10:08 am
Just brill :D :D
January 24th, 2018, 10:52 am
Put a bolt with washer in the dynamo to prevent the ancre from flying of.
January 24th, 2018, 6:05 pm
ImageP1010572 by Robndaisy, on Flickr
ImageP1010571 by Robndaisy, on Flickr
ImageP1010575 by Robndaisy, on Flickr
This is what I've set up to test the ammeter, ignition switch and Regulator/Cutout box. Ammeter moves a little, switch works, no sign of life at the box, fed up now, will troubleshoot tomorrow :) .
January 28th, 2018, 1:37 am
Checked everything again and ran it. Need to let it warm up properly. I don't know why I expected the flamer to leap into life straightaway, it's still trying to hibernate. Will clean the box contacts.
January 28th, 2018, 4:42 pm
OK now, that's a relief, onwards, I'm so far behind I think I'm winning :lol: .
January 28th, 2018, 5:48 pm
Did you connect the mass of the regulator?
January 29th, 2018, 10:19 pm
