View unanswered posts | View active topics It is currently August 14th, 2025, 5:08 pm
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 78  Next
 Van repairs
Post Re: Van repairs
ImageP1010505 by Robndaisy, on Flickr
ImageP1010506 by Robndaisy, on Flickr
Threaded insert ready for braze.
ImageP1010508 by Robndaisy, on Flickr
Well that's that, the fan isn't catching on the cowling anymore. Nice fan ;) .
January 3rd, 2018, 9:15 am
;) nice job..
January 3rd, 2018, 6:00 pm
ImageP1010509 by Robndaisy, on Flickr
ImageP1010513 by Robndaisy, on Flickr
ImageP1010511 by Robndaisy, on Flickr
Good enough,
ImageP1010512 by Robndaisy, on Flickr
ImageP1010514 by Robndaisy, on Flickr
Not so fine on this side though. Might build up with brass?
January 4th, 2018, 9:18 am
ImageP1010517 by Robndaisy, on Flickr
ImageP1010520 by Robndaisy, on Flickr
January 4th, 2018, 10:50 pm
Online
Awesome. :)
You almost inspire me to do some work on my project :D
January 5th, 2018, 9:43 am
The only advice I've ever been offered about 'projects' was to just keep chipping away at them, lots of nice indoor dreaming , planning stuff and then the much harder execution part(which often takes much longer than you ever thought possible). The hardest part of that journey is the first step, trite but true :lol: Right, enough of that B*lls**t,
ImageP1010522 by Robndaisy, on Flickr
I must stay focused ;) .
January 5th, 2018, 10:32 pm
ImageP1010525 by Robndaisy, on Flickr
One of the manifold studs let go at 10 lb. ft. in the cylinder head but I had a 7mm. 8mm. replacement so was able to sort it. Then tightened heads.
ImageP1010526 by Robndaisy, on Flickr
Time to refit the rocker gear and a chance to warm myself up.
Top tip, make sure you don't forget to install the pushrods beforehand ;) .
ImageP1010528 by Robndaisy, on Flickr
Glad that's done.
January 6th, 2018, 5:32 pm
Put some castors from a 'Walls' ice cream freezer on an old work table which is a nice working height for me.
ImageP1010530 by Robndaisy, on Flickr
Getting things ready for bench testing.
ImageP1010529 by Robndaisy, on Flickr
That's your exhaust system :) .
ImageP1010533 by Robndaisy, on Flickr
ImageP1010531 by Robndaisy, on Flickr
January 7th, 2018, 10:02 pm
First let turn the engine over a while on the starter without the ignition switched on. To pump the oil around.
January 7th, 2018, 10:29 pm
yeah that s a top tip,crank over a couple of times with the crank handle then crank with no ignition and it will be all olied up.
January 9th, 2018, 12:00 am
Users browsing this forum: No registered users and 13 guests
