View unanswered posts | View active topics It is currently May 7th, 2026, 11:17 pm
Reply to topic  [ 1004 posts ]  Go to page Previous  1 ... 77, 78, 79, 80, 81, 82, 83 ... 101  Next
 My 2cv
Post Re: My 2cv
Nice, but it's not my 2CV, is it? :lol:
December 7th, 2017, 7:53 pm
Post Re: My 2cv
Oops :o get the mods to move it.
December 7th, 2017, 8:33 pm
Post Re: My 2cv
I have removed the front wing to gain better access to the fuel line as it tracks its way along the chassis behind the front wheel and turns upwards to the pump. When I disconnected the bottom of the last section which goes into the pump plenty of petrol poured out. I reconnected the pipe and tried to start the car but it just won't start. Nothing is coming out of the top of the pump, yet when I disconnected the pipe again, there was petrol in it, which suggests to me that the pump is pulling the fuel up to it, but is not delivering it to the pipe up to the carburettor. Any ideas? Ta.
December 13th, 2017, 12:06 am
Post Re: My 2cv
Yeah. Get a new pump! If you must, then open up the pump and look at the check valves, one in and one out. See if there is a foreign body in the 'in' valve or that the out valve is not stuck closed.
John Jordan
December 13th, 2017, 12:23 am
Post Re: My 2cv
Yeah, you're probably right. It just looks like a bastard of a job. :lol:
December 15th, 2017, 12:10 am
Post Re: My 2cv
I found it easier with a 1/4" drive socket as it gives better clearance. :)
If you've not ordered parts yet, you may also want to get a gasket for the oil filler base, in case you end up removing it.
December 15th, 2017, 9:44 am
Post Re: My 2cv
why should you remove the oilfilter if you have a problem at fuelpump??
December 16th, 2017, 4:09 pm
Post Re: My 2cv
Engine Breather/Oil Filler?
December 16th, 2017, 4:23 pm
Post Re: My 2cv
Yeah, that one :D
December 16th, 2017, 4:52 pm
Post Re: My 2cv
I knew what you were saying, as you did type filler, not filter. :lol:
December 16th, 2017, 6:45 pm
Users browsing this forum: No registered users and 282 guests
