View unanswered posts | View active topics It is currently June 26th, 2025, 8:27 pm
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 78  Next
 Van repairs
Post Re: Van repairs
ImageP1010421 by Robndaisy, on Flickr
ImageP1010422 by Robndaisy, on Flickr
ImageP1010423 by Robndaisy, on Flickr
First attempt(whilst at work) to work out the principles.
Just got to find some suitable pipe(68mm. o.d.) as a pattern, think I've got some somewhere :)
December 6th, 2017, 7:51 pm
Spray can? It isn't a problem if it is a bit smaller you can bend it out en weld it up.
December 6th, 2017, 11:32 pm
Good tip! I found some copper tube that's slightly smaller which'll do.
ImageP1010428 by Robndaisy, on Flickr
ImageP1010429 by Robndaisy, on Flickr
The fan turned up today but there was was no one to sign for it so Yodel took it away :( . I've changed the delivery address to our office so hopefully tomorrow :) .
December 7th, 2017, 1:15 am
ImageP1010430 by Robndaisy, on Flickr
ImageP1010431 by Robndaisy, on Flickr
Wiss, the best 8-)
ImageP1010433 by Robndaisy, on Flickr
ImageP1010435 by Robndaisy, on Flickr
ImageP1010436 by Robndaisy, on Flickr
ImageP1010437 by Robndaisy, on Flickr
Nearly there, dreading this next bit :mrgreen:
December 8th, 2017, 12:53 am
Online
Great job !
December 8th, 2017, 8:42 am
You can apply for a job with citroen... :mrgreen:
December 8th, 2017, 9:08 am
ImageP1010440 by Robndaisy, on Flickr
ImageP1010441 by Robndaisy, on Flickr
ImageP1010442 by Robndaisy, on Flickr
ImageP1010444 by Robndaisy, on Flickr
ImageP1010446 by Robndaisy, on Flickr
ImageP1010443 by Robndaisy, on Flickr
ImageP1010448 by Robndaisy, on Flickr
Original = 153 grammes, Copy = 213 g. have to lose some weight somewhere else, only got 12 HP. :D
December 9th, 2017, 12:19 am
Use aluminuim ;)
December 9th, 2017, 10:22 am
Well Pete, if you'd seen my ally welding all of 30+ years ago it might have been possible and tempting though it is to find a tig set I can't store any more stuff!
ImageP1010459 by Robndaisy, on Flickr
Only -10 last night so time to bring the flamer in from the cold and ready for building up:trouble is, bits/parts have been mislaid over the interminable years this flamin' project has been boring the a**e off everyone so I'll be much more concise in future 8-) .
December 12th, 2017, 11:00 pm
ImageP1010468 by Robndaisy, on Flickr
The unit has a fair bit of oil and dirt on it, best thing to clean it with?
The two leads have lost the insulation, best and easiest fix?
for those of you in Belgium, the BBC tells me that your Telegram service is about to close stop. :)
Did a continuity test, ok.
December 17th, 2017, 11:02 am
