Roger V
 Re: My 2cv
I would be temped to pour a little fuel in the carburetor throat and see if I can get it restarted. Perhaps give the fuel pump a tap with an extension bar as you may have a grain holding a pump valve open.
I have the filter before the pump to help protect the pump.
Make sure all pipes have pipe clips to help stop fuel draining back.
| December 4th, 2017, 2:52 pm |
Jonathan
 Re: My 2cv
How much force should I put behind the extension bar? I've done a pump swap in the past and I don't fancy doing it again if I don't need to. Oh, and as regards a hammer not working on an electric fuel pump, I used to get the SU electric pump stick all the time on my 1961 Minor. A quick tap on the body would free the points and get me going again.
| December 4th, 2017, 7:01 pm |
knightley
Joined: June 19th, 2010, 8:40 pm Posts: 761 Location: Kingswood, S.Glos.
 Re: My 2cv
Change the pump and at the same time fit the SPOG studs which will make the job much easier.
_________________ John Jordan
| December 4th, 2017, 7:23 pm |
Jonathan
 Re: My 2cv
I'll do that after I've given the pump a damn good thrashing, as Basil Fawlty once exclaimed. Only joking but it wouldn't hurt to give it a bit of a knock with a metal bar.
| December 4th, 2017, 10:36 pm |
AZL57
 Re: My 2cv
i would open the pump it's very easy. Than you can see if there is problem in there. Two bolts and 6 screws.
| December 4th, 2017, 11:15 pm |
Roger V
 Re: My 2cv
Whilst your there, check the fuel filter is ok!
Another thought is to fill the tank and therefore raise the level of fuel.
| December 4th, 2017, 11:37 pm |
Jonathan
 Re: My 2cv
The tank was already around half full and I put another £5 worth (at £1.30 a litre) yesterday, as I was checking whether the needle was giving me a false reading. It wasn't and now I have a 3/4 full tank. If I can I'll try to remove the pump tomorrow. I'll have to push the car partially out of the garage to allow me to get the wing off, as the Morris is sharing the single car garage and it's tighter than a tight thing in tightland. If the weather is as crap as the forecast suggests, then I may well not do it.
I see Roy at ECAS sells the SPOG stud conversion, so I'll order that if I need to buy a new pump.
| December 5th, 2017, 12:45 am |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2254 Location: Near Monmouth
 Re: My 2cv
Respray? of tail gate, reinforced hinge area, new window from Acrylic sheet, previous one is somewhere on the Autoroute near Reims  ? Attachment:
| December 7th, 2017, 1:57 pm |
rob massey55
 Re: My 2cv
love the rear sweeps
| December 7th, 2017, 6:12 pm |
subarupete
 Re: My 2cv
Was previously chopped off had it welded back on by LB  As it was In 2006 Attachment:
| December 7th, 2017, 6:28 pm |
