Author |
Jonathan
 Re: My 2cv
I'm thinking about tackling some areas of rust and a bit of corrosion that has been taking hold over the past few years. The shop at the island garage up the road has a Dremel and I have been thinking about buying it to help me remove the rust. Is that a wise move or a terrible one? I mean to be a gentle as possible, but there are a few areas that I think would require a bit more effort to clean up. Comes from living on a very small island with a salty atmosphere.
November 28th, 2017, 12:45 am |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2227 Location: South-Limburg
 Re: My 2cv
Dremel works nice, after ut on some rust converter and than a good primer and paint. Dremel has good little steel wire brushes.
November 28th, 2017, 9:35 am |
Jonathan
 Re: My 2cv
Thank you I have a new problem. I managed to use the car yesterday afternoon and it ran really nice, no issues or concerns. It's been a dry day so far today, so I popped out to the garage and started the car. It started first time and ran fine with the usual amount of choke. It then cut out after half a minute or so and has refused to run after a few attempts to restart. I have over half a tank of fuel, but I don't appear to be getting any of it to the carburettor. I have a fuel filter fitted between the pump and carb, and there is a small amount of fuel in the bottom of it, but after I removed the pipe to the carburettor and placed the open end in an old jam jar, there is no sign of petrol in the jar after I've cranked the engine over. The pump was new around 5 years ago. Car has not done astronomical mileage in that time. I manage around 6k a year. Any suggestions?
November 28th, 2017, 5:00 pm |
AZL57
 Re: My 2cv
Is the piece of tube between tank and fuelline ok? Is your filter in the tank clean? For the rest open the pump body and check if the valves are working. I had one once were a valve came loose of the body. Succes.
November 28th, 2017, 6:01 pm |
Jonathan
 Re: My 2cv
Thanks again for your help. The fuel lines were completely replaced by quite expensive modern stuff at the same time as the pump, so it's not that old, to be honest. Just don't understand how it was faultless yesterday, yet didn't even manage to get it out of the garage today. Doesn't help that sunset is 3pm, so it'll be completely dark by the time I get home from work tomorrow, so no chance of getting it sorted any time soon.
November 28th, 2017, 9:14 pm |
Roco
Joined: November 7th, 2016, 6:23 pm Posts: 49 Location: In the depths of darkest Surrey
 Re: My 2cv
Had a failed pump years back , it left me stranded in the middle of nowhere ,found if I removed the petrol tank filler cap and blew hard into the petrol tank sealing it with my face , it filled the carb and got me another 3 miles each time , but didn’t impress my hot date , she was not impressed with my petrol after shave aroma
November 29th, 2017, 10:46 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1637 Location: Exeter, Devon
 Re: My 2cv
Don't discount the pipe from the tank because it can be difficult to get at, it may not have been changed! When mine failed, I disconnected the long pipe at the front. When no fuel syphoned out, I was suspicious. When I sucked on the pipe, I could feel I was sucking air. In true BBC fashion .... Other faults are available.
December 2nd, 2017, 1:12 am |
Jonathan
 Re: My 2cv
Yeah, the tank was dropped and the entire fuel line was renewed, including that short piece that usually ends up causing trouble. Even though that was around 5 years ago the pipe still looks to be in very good condition (what I can see), but that's not to say it's still good at the tank end.
December 2nd, 2017, 7:55 pm |
 Re: My 2cv
As long as the 'front to rear' pipe is the original (nylon) type, you've only got to worry about the short lengths of rubber hose at either end. That hasn't stopped some folk from using rubber hose from 'end to end', which isn't the best plan, in my opinion. All fuel hose is permeable, albeit to differing degrees and it's usually only the inner lining of a hose which is resistant to ethanol...
December 3rd, 2017, 3:15 am |
Jonathan
 Re: My 2cv
Managed a quick half hour session this afternoon which seems to have provided me with fairly concrete evidence. I had already removed the pipe from the carburettor as mentioned previously and found no fuel flowing up from the pump. Well, today I removed the pipe at the junction behind the front wheel and fuel pissed out from the tank side of the pipe. So clearly the fuel line from the tank to the front of the car is fine. That only leaves the pump as the culprit, unless someone can suggest another cause.
December 3rd, 2017, 6:29 pm |
Users browsing this forum: No registered users and 15 guests |
