View unanswered posts | View active topics It is currently February 4th, 2026, 12:06 am
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 78  Next
 Van repairs
Post Re: Van repairs
ImageP1010308 by Robndaisy, on Flickr
Here it is in Piet Olyslager's book.
The unions on this engine were not bound and not loose either.
November 8th, 2017, 8:16 pm
425 cc. rings.
ImageP1010311 by Robndaisy, on Flickr
Middle ring at the top of the pic.
ImageP1010312 by Robndaisy, on Flickr
Oil control ring , main ring, backing piece and two very thin rings that above and below the main one. Is this normal?
The thin,almost shim like pieces that the rings sit against, what are they for? Are they scrapers?
Keeping them all in the order and the way up that they came out though.
I'm well confused by 'em!
November 11th, 2017, 12:45 pm
ImageP1010313 by Robndaisy, on Flickr
ImageP1010314 (2) by Robndaisy, on Flickr
A touch of Doctor Who?
ImageP1010315 (2) by Robndaisy, on Flickr
Both pistons have been around the block :) .
November 11th, 2017, 7:34 pm
I've removed the spring clips but the flamers won't move.
ImageP1010318 by Robndaisy, on Flickr
If I support the rocker shaft posts
ImageP1010322 by Robndaisy, on Flickr
can I drift the shafts out? I'd like them out because it's better on re-assembling.
One of you must have done it, don't hold back Bois! ;)
November 11th, 2017, 10:01 pm
Leaving well alone...
ImageP1010324 by Robndaisy, on Flickr
Pressed the pin out a fair way and it is still a very good fit in the posts.
So stopped and thought about it. I can get the pin out with some difficulty
but re-installing it (without damaging/mashing something)when the head is fastened to the crankcase? I can't guarantee it. Also because the pin has a flat on one end which bears against a bush that one of the head studs goes through(hope you're keeping up!), the chance of that engaging correctly with the pin being so tight are slim. So I pressed the pin back in and will have to be careful when refitting the heads. The bottom ends of the push rod tubes show signs of careless assembly some time ago :roll: . So that's 1 to the engine and 0 to the amateur home mechanic :D . The game's not over yet though, this flamer has slumbered long enough.
November 13th, 2017, 9:56 pm
Very wise decision !
November 13th, 2017, 10:19 pm
Rob,
did you try heating the rocker shaft pedestals with a blowlamp?
Differential thermal expansion between the alloy and the steel shaft.
Yes, I did do it, many years ago, with one of the 500cc conversions for these engines... ;)
November 13th, 2017, 11:02 pm
I might have known you would have!
I'll think about it a bit more...then probably wade in :) .
November 14th, 2017, 8:22 am
ImageP1010332 by Robndaisy, on Flickr
Ready,
ImageP1010339 by Robndaisy, on Flickr
ImageP1010341 by Robndaisy, on Flickr
Steady,
ImageP1010342 by Robndaisy, on Flickr
Done, Thanks Ken :) .
November 19th, 2017, 3:58 pm
Like your newpaper under it..."This is beyond our abailities... ;-)
November 19th, 2017, 7:52 pm
Users browsing this forum: No registered users and 897 guests
