View unanswered posts | View active topics It is currently February 4th, 2026, 12:08 am
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 78  Next
 Van repairs
Post Re: Van repairs
ImageP1010252 by Robndaisy, on Flickr
ImageP1010259 by Robndaisy, on Flickr
More Van Rouge just like what was in the fuel tank, some one has been kind and put some fluid in for preservation.
ImageP1010254 by Robndaisy, on Flickr
ImageP1010266 by Robndaisy, on Flickr
Here's the broken stud I mentioned earlier. I thought I'd try to move it with a centre punch and hammer just in case it was my lucky day.
ImageP1010275 by Robndaisy, on Flickr
That was lucky!
ImageP1010273 by Robndaisy, on Flickr
ImageP1010282 by Robndaisy, on Flickr
ImageP1010278 by Robndaisy, on Flickr
How do I get this flamer off? Not another 'special tool'? :o :cry:
November 3rd, 2017, 9:36 pm
Loose the wires and the 2 nuts top and bottom. Remove the brushes. Carfully there is a wire at the underside of the aluminium shield connected to the coils. Use a soft hammer to tap the aluminum shield off. Than you can tap with the hammer left and right to the body of the dynamo and pull on it it will come off slowly. Than you need a large m20 bolt you turn in the ancre and this will be pulled of. No special tool.
http://guillon2cv.free.fr/documents/dic ... che79.html
November 3rd, 2017, 11:22 pm
Thanks Fer.
November 4th, 2017, 6:13 am
Just found out that by clicking on the horizontal arrows over the image there's more, a lot more diagrams, thanks very much!
November 4th, 2017, 11:57 am
Yes it is the complete repairhandbook from the 50s ;-)
November 4th, 2017, 6:04 pm
ImageP1010287 by Robndaisy, on Flickr
Gently tapped around the casing with light pressure from the screwdriver and it slowly released.
ImageP1010288 by Robndaisy, on Flickr
Haven't got a 20mm. fine thread bolt yet.
ImageP1010289 by Robndaisy, on Flickr
The inner gear has a tiny woodruff key which I nearly lost when removing the camshaft from the half casing!
ImageP1010290 by Robndaisy, on Flickr
ImageP1010294 by Robndaisy, on Flickr
ImageP1010293 by Robndaisy, on Flickr
No obvious sludge inside, I wish I'd left well alone :) .
Better get it all cleaned up .
November 4th, 2017, 6:25 pm
ImageP1010303 by Robndaisy, on Flickr
probably explains this,
onward with the endless cleaning... :D
The separate pushrod tube seals are rock hard too.
November 7th, 2017, 9:47 am
put it in the dishwasher... ;-)
November 7th, 2017, 10:40 pm
I did, ours is called a sink ;)
ImageP1010306 by Robndaisy, on Flickr
ImageP1010305 by Robndaisy, on Flickr
Those little holes in the heads of the Banjo bolts...the van hasn't got to fly :mrgreen: Never seen facility for locking wire anywhere else on the flamer.
November 7th, 2017, 11:51 pm
Yes they are bound to the tubes.
A friend once was surpised by his parents coming home from holiday when he was sitting in the bathtub degreasing an engine....they were not amused ;-)
November 8th, 2017, 6:43 pm
Users browsing this forum: No registered users and 917 guests
