View unanswered posts | View active topics It is currently April 28th, 2026, 10:48 am
 rear box rubber mounts ?
Post rear box rubber mounts ?
Hi, I have a question, does anyone know what rubber mounting is used on the rear of the rear box in a Louis Barber 4x4 mine has gone a bit perished, I have ordered standard type engine front mounts for the front of the back box, but I don't know the origin of the rear one..
Thanks
October 5th, 2017, 5:01 pm
Post Re: rear box rubber mounts ?
Thanks
I know that mr. Barbour uses a lot of mountings from Landrover, so I guess it will be used here too.. Can you make a foto and post it here...
P.s. Take a look at his site and sent him an email.
http://www.barbour4x4.com
October 5th, 2017, 5:23 pm
Thanks will do
October 5th, 2017, 5:27 pm
Contact from web page not firing up at the moment, will try later, meanwhile going to look on some Land Rover sites for clues ;-)
October 5th, 2017, 5:33 pm
Likely to be Peugeot mounts, on later designs ???
October 5th, 2017, 5:44 pm
This car was built 2002, if thats any help.
October 5th, 2017, 7:10 pm
Seen in circle
October 5th, 2017, 8:26 pm
Pretty sure thats from a Peugeot, does it need replacing?.
On my version (2003) I have 2 mounts and they are fine, the front ones have been done a few times as they shear into two parts.
October 6th, 2017, 9:22 am
From LB
Rear single mount is probably from an AX gearbox top mount
later versions use Saxo gearbox top mount
October 10th, 2017, 9:33 pm
Thanks
October 19th, 2017, 6:56 pm
Users browsing this forum: Bing [Bot] and 17 guests
