Nelsthebass
 Losing Oil
My 652cc conversion runs well, is reasonably economical - 40-42mpg - but on a long run seems to burn a lot of oil - we have come over to West Wales and it has lost around 500ml in 180 miles but pottering around here has used none - is it something to do with running at higher road speeds and engine revs that is pointing towards knackered rings or poorly run in rings/barrels or valve stem seals or something else - it doesn't drip a fat lot of oil, is not losing anything from the head banjos and I put a new breather on it a couple of months ago????
| May 31st, 2017, 7:37 pm |
Derek
 Re: Losing Oil
I would suggest worn rings in the main, but look at the one way valve in the oil filler tower (as well as Valves, guides and seals).
Do a compression test and leak down test, and see what a manometer reading shows on crankcase vacuum.
| May 31st, 2017, 10:05 pm |
Nelsthebass
 Re: Losing Oil
Thanks for the response - the breather is a new improved from Roy so I would rule out crankcase pressure - I'm buying a compression tester when I get home but any other thoughts are welcome
| May 31st, 2017, 10:21 pm |
ChrisW
Joined: February 21st, 2012, 9:01 pm Posts: 1136 Location: Avranches, Sud Manche, France
 Re: Losing Oil
Blue smoke ? Why do I bother asking !!!!!
| June 1st, 2017, 10:35 am |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1655 Location: Exeter, Devon
 Re: Losing Oil
What's a leak down test? Edit I looked it up https://mobiloil.com/en/article/car-mai ... kdown-testClever  I want one Check ignition timing!
| June 1st, 2017, 11:06 am |
Nelsthebass
 Re: Losing Oil
Why timing?
| June 1st, 2017, 11:37 am |
Roger V
 Re: Losing Oil
To advanced can cause higher pressure and blow by. I'm sure I read it on here somewhere. But I have been asleep since then. I'll see if I can find it.  Ta da viewtopic.php?f=7&t=5516&p=117372&hilit=%2AOil%2A#p117372Not quite as I remembered it, but Sean mentions it here for an oily airbox.
| June 1st, 2017, 12:17 pm |
Nelsthebass
 Re: Losing Oil
I think I follow Kens logic but I don't have an oily air box - ( oo er Missus! In best frankie howerd mode)
| June 1st, 2017, 6:27 pm |
 Re: Losing Oil
yup however as its not blowing oil just burning it id be suspecting oil controll rings or some other issue with the bore or rings if its burning it you will see it as deposits on the stem of the exhaust valve or as a tan buildup on the plugs
dont rule anything out do a maniomiter test ive seen those breathers not working at all due to swarf under the reed valve
| June 1st, 2017, 7:09 pm |
Nelsthebass
 Re: Losing Oil
Confused.com! Came back from Wales at the weekend and doesn't appear to have used much oil at all! What could possibly cause it to lose oil sometimes and not others???
| June 5th, 2017, 11:51 pm |
Users browsing this forum: No registered users and 5 guests |
