View unanswered posts | View active topics It is currently June 19th, 2026, 8:38 am
Reply to topic  [ 7 posts ]
 Gearbox shims
Post Gearbox shims
Hi all
Where can I get gearbox shims?
The bearing on the primary shaft. Any tips on changing it if you don't have a press?
Any thoughts appreciated. :)
May 15th, 2017, 1:03 am
Post Re: Gearbox shims
Bearing changed :D
So ..... about these shims!
May 26th, 2017, 2:19 pm
Online
Is it the top shaft (primary)?
Use the shim you had and adjust the selector forks if required.
Only the lower shaft(pinion) need a shim to set the pinion distance if the rear bearing has been changed.
Gearbox Guru Rick is you man really.
May 26th, 2017, 3:44 pm
Thanks Pete
As per Haynes, I wanted to adjust the end float on the layshaft and main shaft.
I found the following site.
https://www.thebearingcompany.co.uk/cat ... egory=1716
Can't find the gearbox pixie dust section, but will give it a go. :D
I may be some time. ;)
May 26th, 2017, 11:25 pm
Roger,
any chance of letting us know which section of Haynes you're working from, so that this shim can be identified?
Struggling with nomenclature here, it'd be a lot easier if everyone used 'input shaft', 'main shaft' and 'pinion shaft'... ;)
May 26th, 2017, 11:55 pm
Hi Ken/Pete
Haynes page 76. Gearbox section. Gear adjustment.
Endfloat - 2nd gear idler
Roller thrust bearing
Page 83, 2nd image for measuring current endfloat on mainshaft. I was going to add a shim next to the spacer collar.
Page 84 for measuring reduction gear/laygear endfloat. I was going to add a shim to either end of the existing shims as appropriate.
There is play in both of these areas. I was mostly trying to reduce the layshaft moving up and down the pinion shaft.
Of course ....... I could be being to pedantic. :ugeek:
Thanks guys
May 27th, 2017, 12:19 am
My Haynes manual 196, 1967 - 1990, shows these items just one page before those stated; 75;82;83.
May 27th, 2017, 6:35 am
Users browsing this forum: No registered users and 211 guests
