View unanswered posts | View active topics It is currently June 20th, 2026, 12:21 am
Reply to topic  [ 4003 posts ]  Go to page Previous  1 ... 352, 353, 354, 355, 356, 357, 358 ... 401  Next
lpgo wrote:
turbofiat124 wrote:
After a pissy raining winter,
3) Swapped green and yellow wires on headlight switch. So the dipped beams are on when the stalk is pulled toward me and main beams away from me. Like my Subaru and Chevy van. ".
You should change the Subaru and Chevy... Not the 2cv.
Yeah but the Subaru and Chevy van has killer heaters! If I had to drive my 2CV in the winter, I'd carry a blanket with me...
April 3rd, 2017, 9:13 pm
Hi everyone. :)
Anyone know what this fuel gauge and voltage indicator is from?
April 3rd, 2017, 11:58 pm
Doh
April 4th, 2017, 12:01 am
Definitely Dyane, m'dear. :)
April 4th, 2017, 2:27 am
Thanks Ken
Is it compatible with a 2CV senderwould anyone know where I can get the connector for it?
Cheers
April 4th, 2017, 9:28 am
Roger V wrote:
Thanks Ken
Cheers
Yes it is, and propably only way to get correct connector is from scrapped Dyane...
What I have find about senders, DS, CX, GS, SM, BX and Xantia have same type on fuel/temp gauges/senders. I have had succesful installing over 15 years on my Dyane, original fuel sender with BX gauge, and when I examined that we had plenty of scrapped cars to have gauges/senders to measure/test...
April 4th, 2017, 10:15 am
Thanks Jasu
It will save me a lot of fuses if I could get an idea of what connects to which pins. Supply, sender and negative rather than colours if possible.
Anyone :)
April 4th, 2017, 10:55 am
Bedouin's going well!
Touch wood :lol:
April 21st, 2017, 3:03 pm
Another MOT test past by the Ami - minor advisories but same as last years so no degradation. Noticed the charge needle wasn't behaving on the way back from Richard Daltons and when I checked the voltage with my multimeter didn't appear to be charging - narrowed it down to the regulator so stripped it down and cleaned and adjusted gaps and now pulls 14v nicely.
April 22nd, 2017, 6:56 pm
Steering wheel bolts were a bit loose the other day! When I went to check them out, one was ok, one was dodgy and one was stripped.
As per advice on this forum, I ordered M8 Allen key heads.
They arrived today and were fitted. Less than a half hour.
I don't suppose others jobs will be so easy but sorted. :D
April 22nd, 2017, 10:59 pm
Users browsing this forum: No registered users and 157 guests
