View unanswered posts | View active topics It is currently June 19th, 2026, 7:13 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 70, 71, 72, 73, 74, 75, 76 ... 105  Next
 Make Your Own ....2CV.... 4x4
Nice work, as usual :)
March 28th, 2017, 1:03 pm
For AZS
Drive Shaft Adaptors
March 28th, 2017, 2:16 pm
Modified the C5 struts to allow fitment of a coil spring, so that the static ride height is set without the need of the LDS part of the strut
Did a calculation for the spring and it is far to soft :( :(
The spring sits have way along the arm so 400 lbs/" ??? would be far better than 240lbs/" :(
March 30th, 2017, 2:13 pm
subarupete wrote:
For AZS
Thanks a lot Pete!
March 31st, 2017, 2:40 pm
Almost ready to go to Morvan :D
April 1st, 2017, 12:36 pm
Prop Shaft couplings and Transfer-Gear with quality TIG welding by Martin at MTech Ltd.
April 4th, 2017, 6:36 pm
Assembled the main parts, ALL rotates without problems :shock:
Need shim washers etc etc and finish the back-plate.
April 6th, 2017, 3:35 pm
Will this gearbox w/ PTO being going to Morvan Pete!?
April 7th, 2017, 7:23 pm
Wiil be going, hopefully inspire some other ideas.
ps
Its only a diff, gearbox/transfer box will sit behind the steering tube.
April 7th, 2017, 7:52 pm
Springs, Springs and more Springs.
Found some soft front 2cv springs, fitted as Coil-Over they seem to be about right.
Just need to fabricate a stronger top mount :oops:
April 25th, 2017, 12:26 pm
