View unanswered posts | View active topics It is currently June 19th, 2026, 9:11 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 63, 64, 65, 66, 67, 68, 69 ... 105  Next
 Make Your Own ....2CV.... 4x4
I was thinking something like that..:
Gears from 652 Visa to GS 5-speed case with 5-speed pinion and differential. Modify 5th gear selectror fork to operate rear wheel connect/disconnect. Removed the upper 5th gear. So the prop shaft will go under steering tube, and inside of frame. And with use of three gear, there can use same C/P -ratio at rear diff what is at front diff, I couldn't find any combination to have same ratio if there is used only two gears (from 2cv, Visa or GS)...
November 18th, 2016, 8:45 pm
That is a clever solution, that allows disconnection of the rear drive.
November 18th, 2016, 11:29 pm
With a Gs visa Lna gearbox you never can make low gearing (or am I wrong???) With my solution (2cv front gearbox) you can.. Taking the rear pinions out, taking power from the upper shaft out, put it through a transferbox (you alraedy have) and go back to the lower shaft back into the gearbox. Now you have 3 gears high and low gearing at front and back. Yu need to use your newmod. gearbox at the rear then...
November 18th, 2016, 11:57 pm
OK guys here you go with the latest madness.
Front box with diff and shafts could be made from 2CV gearbox or GS.
Rear Diff could be made from a 2CV box or GS.
The remote 4 speed box made from GS 5 speed box, however this could be made from a 2CV box if there is a reliable method of putting an output flange on the pinion??
4x4 new design 2016.pdf [37.31 KiB]
Downloaded 372 times
November 19th, 2016, 11:45 am
yup. This works for me...
November 19th, 2016, 12:10 pm
Pete: You could also have 1-2-3 -speeds on "first gearbox", if you want. And about flange to pinion shaft, maybe the best way is to shorten the case like you did on your diff case..?
Geo: Those photos what I put, is thinking of my 4x4 "next solution", tried to explain but words wasn't enough so photos tell more. And all started from my question to Pete, "does he have those 5th gears to sell for me", I have one pair but need of another pair...
Hmm, maybe I should post them to my topic..? :roll:
November 19th, 2016, 12:44 pm
@Jasu 3 more gears :shock: and post stuff to keep the forum busy...
Re GS gearboxes.
Now RARE in the UK, as some BMW engined A series are using them.
Still some in France @ €100 upwards :(
Re Gear Ratios with Current Setup
Main box GS (not LN ratios) and modified TBox (RockLobster in the Suzuki camp).
HI Range
1st = very low crawler gear
2nd = 1st
3rd = 2nd
4th = 3rd
LOW Range
All gears LOWER again, need steep terrain to evaluate.
November 19th, 2016, 1:27 pm
Very unhappy chap today, as the Y Axis screw/control on the milling machine has JAMMED solid.
Without the mill can't machine any of the difficult gearbox parts etc :( :( :(
November 20th, 2016, 1:14 pm
I'm very unhappy too scrapped my tps sensor (height sensor) when making a testboard. I have toorder a new one
Shit happens..
November 20th, 2016, 3:58 pm
http://www.citroenet.org.uk/passenger-c ... /a4x4.html
November 21st, 2016, 8:15 pm
