View unanswered posts | View active topics It is currently November 19th, 2025, 9:38 pm
Reply to topic  [ 4 posts ]
 Speedometer interchangabilty
Post Speedometer interchangabilty
I hope this doesn't sound like a dumb question but can I swap out my Veglia speedometer/instrument cluster in my 2CV6 that reads in KPH to MPH without having to replace the gear drive in the transmission? I would imagine the only difference between a KPH and a MPH speedometer are the numbers. But would the odometer be accurate? Or would it be off by .6 ?
I've seen some on Ebay.UK. Some are made by Veglia and some by Jagger. Is there a difference? Otherwise they look the same to me.
September 26th, 2016, 12:14 am
Post Re: Speedometer interchangabilty
i don't think there any problem in switching the speedos. And the maker is Jaeger. You can use Veglia or Jaeger i think citroen did use whatever was cheaper or available. Some times due to strikes in several factories. So i had a Landrover that had a french ducellier ignition due to strikes at Lucas.
September 26th, 2016, 8:27 am
I swapped out a 425 engine and Traficlutch gear box for a 605 engine and later gearbox on my AZU 250. the speed reads high by about 10 Kph.
September 29th, 2016, 7:23 pm
of course they have different gearboxes. But the 2cv6 ones should be interchangable.
September 29th, 2016, 9:07 pm
