View unanswered posts | View active topics It is currently June 19th, 2026, 12:44 pm
 Shiftier lubrication?
Post Shiftier lubrication?
I hate to bombard the forum with all these questions. It would be great if my Haynes manual would get here so I could read up on some of these questions.
The shiftier on my car just feels like it needs lubricating in the shaft in the dashboard.
Is this a maintenance item? Just shift the car into a known gear like 3rd, disconnect the shift rod from the gearbox, clean it up a bit and grease it with something like a graphite based grease?
September 6th, 2016, 7:24 pm
Post Re: Shiftier lubrication?
Use Talcumn Power, oil based products ruin the bushes.
Ps The forum is very quite, so activity is great.
September 6th, 2016, 7:48 pm
Thank you.
This forum as been a wealth of information. Thanks to everyone who has answered my questions.
September 6th, 2016, 8:50 pm
Talcum or graphite powder only!
What conditon is the gear change Rubber o ring in? The one that's the link between the horizontal gear chanhe the vertical rod from the gearbox.
September 6th, 2016, 10:05 pm
Hadn't thought of talc etc. I've only used silicone spray but it does dry out.
September 6th, 2016, 10:38 pm
I've never had talcum or graphite powder in my workshop as I know of. I have silicone spray though. Isn't that ok to use?
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
September 7th, 2016, 12:29 am
What condition is the gear change Rubber o ring in? The one that's the link between the horizontal gear change the vertical rod from the gearbox.
O-ring? I'll have to look at that to see what your talking about.
September 7th, 2016, 12:31 pm
It's not a normal O ring, but a rubber bush surrounding the plastic bush which is in contact with the gear lever shaft.
Here is what it looks like.
http://www.ecas2cvparts.co.uk/bushes-ny ... -1181.html
John Jordan
September 7th, 2016, 12:37 pm
I use a silicon spray and find it great, also while your sorting the gear action out make sure the heater pipes aren't fouling it :-)
September 7th, 2016, 1:34 pm
What conditon is the gear change Rubber o ring in? The one that's the link between the horizontal gear change the vertical rod from the gearbox.
You're each talking about different components here!
September 7th, 2016, 8:44 pm
Users browsing this forum: No registered users and 216 guests
