View unanswered posts | View active topics It is currently February 3rd, 2026, 10:14 am
Reply to topic  [ 153 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 16  Next
 Long term project, Dyane4x4
Post Re: Long term project, Dyane4x4
Something about dash...
Testing how gauges and lights work...
Need to solve an issue with fuel gauge. On full tank, the needle goes only to about half, empty is ok. The gauge is for 0-180 ohm sender, but the sender is 0-70 ohm. A little amplifier, some electronics, may solve that..?
July 8th, 2016, 11:52 am
Like analogue gauges.
You may need to adjust your "main beam" led or your Retina may complain:)
July 8th, 2016, 1:02 pm
Those lights are an old fashioned bulbs, and I'm not worried about brightness. Direct fron H-D Sportster and they doesn't disturb at all on them...
I could be wrong about, but if that is too bright it's simple to fix...
July 8th, 2016, 2:49 pm
Cool :)
July 8th, 2016, 6:12 pm
how are you driving the speedo?
July 8th, 2016, 9:05 pm
jasu wrote:
Speedometer "problem" is also another story. I didn't like to have three meter long speedo cable, so why not go electric..?
Sensor from Harley Davidson Sportster, drilled hole trhough the case. Surprising, it doesn't leak...
Tested by rotating the sensor, how it should be aligned. The best position, it could read teeth near 20mm distance...
Testing, testing. When I get the spedo installed to dash, need to verify with GPS. By calculation, it should be accurate enough, less than 10% wrong, but can't be sure now...
Hall-sensor reading teeth of gear... Again H-D -parts...
Today made some brackets to hold speedo and RPM gauges...
Oh, and if I ever get to GB with that car, I can easily swap KM/H gauge to MPH gauge. As you can see, they show correct speed, both are sent by same sensor on that testing...
July 8th, 2016, 9:10 pm
Quite neat? Still some work ahead with dash...
Took the rear differential out, 4x4 worked well, but after removed RPM limiter and over-boost protection, the rear wheel drive stopped working... :lol:
The inner part, what is taken from clutch center, was installel by heating (don't know correct term in english) and also welded from holes. Wasn't strong enough, now it's welded again, with larger seams, but if that break again I need to make new design. Some idea is on my mind, hopefully I don't need them...
Funny, I didn't even feel sad after that, those happenings are only part of "motorsport"... :roll:
July 9th, 2016, 9:47 pm
Jasu,
considering how difficult it is to see the speedometer on a Dyane, especially if you're above average height, I reckon that your version of the dash is how it should have been done.
Re. your 'test load' of the rear drive connection, wouldn't a 'long spline' input shaft give more purchase on the clutch disc splines?
You might even be able to double up on the clutch disc centres.
Ken
( p.s. How many 'spare' Dyanes did I see in one of the videos you posted earlier.
I thought I had a problem in that area...
:lol: )
July 9th, 2016, 10:40 pm
Perhaps use the "Whole" centre of the clutch plate.
Grind out the rivets then, mount using the existing rivet holes????
See
July 10th, 2016, 11:05 am
Ken, on that video, all those aren't mine, but there is some more outside, and another place also some. And those what are inside aren't "parts cars" or "spares", near rust free examples. We are decided to build some more room to have more of them inside...
Pete, there is clutch center part on gearbox output. Reason why I didn't use that on rean input, is need of carrier bearing. But after well sleeped night, I'm sure it will break again there, so that area need to redesign somehow... Maybe that axle to viscous coupler is need to make several pieces, one for bearing, then clutch center disc, and then axle for viscous, all bolted together by original holes of center but drilled larger like on gearbox output..?
And yes, it was really enjoy to see all four wheels throw gravel when the engine didn't cut-off by boost protection, just before breakdown..! :lol:
July 10th, 2016, 11:18 am
