View unanswered posts | View active topics It is currently April 29th, 2026, 1:36 am
 Pushrod tubes - Cracked? Replacement.
Post Re: Pushrod tubes - Cracked? Replacement.
Probably the pads have got oil on them too - whilst the discs can be cleaned, the pads will tend to absorb the oil - may have to change them I'm afraid...
May 1st, 2016, 11:13 am
I think you're right. I left the cap off and soaked the engine bay totally, a year or two ago. The brake pads survived that, (brakes were barely working at first!) but I pressure washed the brakes with a very hot washer and hadn't driven so far. Pretty sure 250 miles will have done it this time though, lol.
I should stop the oil leak first really.
May 1st, 2016, 1:18 pm
I spent an hour or so fiddling with the leaking pushrod seal today, and (I think) success! I cleaned it all off well and observed it each time, leaking quite heavily at times depending on how I fiddled with it, eventually I poked the cup around enough and moved the spring around a bit, and it's pretty much done the trick. It's almost as if a slightly stronger spring would help.
The seal on the other tube is not leaking at all.
I've only driven a few miles but the sump is still bone dry. Yay..
May 18th, 2016, 6:36 pm
Good to hear!
May 18th, 2016, 9:21 pm
Thanks. I see a set of brake pads in my near future now, lol. Brake cleaner isn't gonna save em this time I don't think.
Very happy it's hopefully sorted now though.
May 18th, 2016, 9:41 pm
Must find the time to take a good look at the pushrod seals on the engine of my 2CV. Still has a massive leak, but been very busy recently.
May 18th, 2016, 11:24 pm
Jonathan, is it not getting all over the brakes? I only noticed because it suddenly developed a massive pull to the left. Motorway use was what blew it over the brakes though, actually.
May 18th, 2016, 11:34 pm
Has covered everything everywhere under the bonnet. Very annoying really. No sign of oil leaking when engine not running. Pisses out when running. Not getting any use because of the issue.
May 21st, 2016, 9:15 pm
Yeah once I went fast enough in the wind, the leak was enough to just get some on the flywheel. And from there, everywhere else..
May 22nd, 2016, 12:17 am
Still not a drip to be seen on the sump, and I've been to Newbury and back on the M4. Very pleased.
May 23rd, 2016, 9:46 pm
