View unanswered posts | View active topics It is currently June 20th, 2026, 12:41 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 58, 59, 60, 61, 62, 63, 64 ... 105  Next
 Make Your Own ....2CV.... 4x4
I hope it doesn.t leak oil now it is welded... Itbis always a fu..ing pain in the ass when these sorts of welds are lesking
. Otherwise it looks Great to me... Next step would be making your own diffs... I think mt. Pony Will be very jeslous when he sees This..
April 8th, 2016, 5:14 pm
Getting serious now?
Machining the Pinion Shaft, reduce diameter to fit the new bearing and cutting a new thread M24 x1.5 on the shaft end. Will then cut of the extra bit...
April 9th, 2016, 3:55 pm
Progress with the Stumpy diff.
Back Plate with mountings.
April 14th, 2016, 12:20 pm
April 14th, 2016, 7:12 pm
Bit more machining
Back Plate.
Pinion shaft.
Flange is from a LR and the splines seem?? to be a good fit.
April 22nd, 2016, 12:09 pm
In between painting (Creocote) many fence panels , I did the easy top half of each panel
Completed the back end of the diff.
Rear Oil Seal mount
April 26th, 2016, 12:45 pm
With this quality of work you should go out on your own and give master pony some competition ;-)
Luv it.
April 26th, 2016, 8:31 pm
@Harley.... I think he's now retired.
Started the front end ...
April 29th, 2016, 6:22 pm
Output Flange finished with splines, "wire eroded" by Screwtech
Plate to retain Oil Seal for the new output flange.
Support Bracket
Milled holes to reduce the weight, bit more to go, so that it is the same weight a 2 Engine mount brackets.
May 4th, 2016, 4:09 pm
Final Machining/polish of the output flange so it fits the Oil seal.
Video of shaft in the lathe
https://youtu.be/haFgHuzzbK8
May 15th, 2016, 3:06 pm
