View unanswered posts | View active topics It is currently June 19th, 2026, 12:44 pm
 Manifold removal - split the nuts?
Post Manifold removal - split the nuts?
I reckon the manifold on my '88 (M28 engine) car probably hasn't been off since it left the factory, there's nothing really left of the nuts at the front.
I've got a worsening gasket leak and after a year I think it's time to do something about it!
Was thinking of splitting the nuts off with something like this:
- A good idea?
Any other tips?
March 21st, 2016, 4:17 pm
Post Re: Manifold removal - split the nuts?
Will you have enough room for it - the nuts are in a recess in the manifold.
March 21st, 2016, 5:15 pm
Hmmm good point - failing that. Any tips for getting them off?
March 21st, 2016, 6:27 pm
Sam, I use a small cold chisel to cut away part of the remains of the nuts.
Something like this...
http://www.ebay.co.uk/itm/ECLIPSE-SPEAR ... v0WU-g_tNw
If you point the chisel in the direction that the nut would unwind, you should find that it 'peels' away from the thread, leaving it undamaged...
March 21st, 2016, 7:23 pm
I've given up eBay for Lent :lol:
But thank you I'll have a look for one after Easter!
March 21st, 2016, 11:21 pm
you can buy a small cold chisel from your local tool shop or even DIY barn
Imagesplit the other nuts off by that is my real name!, on Flickr
March 21st, 2016, 11:51 pm
But, that's not a penance or a hardship!
That's a relief... :roll:
March 21st, 2016, 11:53 pm
Certainly is for our posty :lol:
March 22nd, 2016, 1:40 am
Make sure you take note of seans picture and use the manifold as a aid to rest the chisel thus benin more accurate
March 29th, 2016, 7:35 am
Sam, I had a one I could not shift, so I cleaned up the offending nut and welded a new nut over the offending one then removed the stud and nut as one, new stud from ECAS all good :-)
March 29th, 2016, 11:39 am
Users browsing this forum: No registered users and 216 guests
