View unanswered posts | View active topics It is currently June 20th, 2026, 12:41 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 56, 57, 58, 59, 60, 61, 62 ... 105  Next
 Make Your Own ....2CV.... 4x4
I would add some gussets etc otherwise you could be slowly sitting lower and lower after rough road
February 18th, 2016, 7:23 pm
Got Bored doing the seat in the cold.
So swapped the gear ratios.
LNA 4 speed gears on to a 5 speed main shaft.
GS____1st - 3.818 2nd -2.294 3rd - 1.500 4th - 1.133
LNA___1st - 4.545 2nd -2.500 3rd - 1.607 4th - 1.147
ps Circlips/Snap Rings without holes were designed by the devil!
ps Where has the the Jerome Cats -2CV site, gone?
LNA Shaft.
GS (longer with spline)
February 27th, 2016, 1:57 pm
Apparently Jeroen Cats site is offline, hopefully only temporary.
Maybe this could be of help: http://archive.is/0Kyx
February 27th, 2016, 8:09 pm
Jeroen Cats died in an accident between a truck and his Ami 8 service about 3 miles from my home..... if I remember right at was 2007....
His father managed the website but has choosen to take it offline...
Somebody else is now reconstructing bit by bit the website (without permission).. So we will hope this will last...
http://dyane435.wix.com/cats-citroen
February 29th, 2016, 1:08 pm
Ta for that, found the site very useful.
February 29th, 2016, 3:35 pm
Bits done in the warm.....
Rear output shaft of my new gearbox, together with the part machined (by me) output flange.
February 29th, 2016, 3:38 pm
where is the gearbox comming from..... Which lathe do You have
March 5th, 2016, 10:22 am
Citroen LN from 2cviking.
Harrison 140 (with Inverter/speed controller)
March 5th, 2016, 10:42 am
Made a carrier for the new rear lip seal.
As M9 are difficult to source, drilled/tapped the casing for M10.
March 8th, 2016, 1:53 pm
Gearbox output flange sans splines.
Doesn't look much, but a local machine shop would charge about £150+.
May try and get the splines "wire eroded", else its a weld to the the syncro flange, not that bad as its a weld similar in dimensions to skinny prop shafts.
WIP
Untidy End.
Tidy End
March 9th, 2016, 5:34 pm
