View unanswered posts | View active topics It is currently June 19th, 2026, 2:22 pm
Reply to topic  [ 35 posts ]  Go to page 1, 2, 3, 4  Next
 water
Post water
Rain water coming from the front windscreen, etc - any tip to stop it while waiting for repairing, whatever is wrong?
Thanks!
January 19th, 2016, 1:18 am
Post Re: water
Thanks!
(duck) Tape ??
January 19th, 2016, 1:04 pm
Post Re: water
Tape is OK but I was thinking of sth like a plastic gutter to make water slide to somewhere far away from my legs, especially the right one. ;)
January 19th, 2016, 4:32 pm
Post Re: water
Pump some polyurethane PU40 from toolstaion all round under the rubber, that should sort it :-)
January 19th, 2016, 9:11 pm
Post Re: water
And, will it be easy to remove it in summer, or will it act like a glue?
January 20th, 2016, 11:20 pm
Post Re: water
Or use clear silicon bathroom sealant - that tends to unpick easily. Use a relatively small nozzle aperture and lift the windscreen seal on outside and run around the seal et voila! Dry feet again.....
January 20th, 2016, 11:30 pm
Post Re: water
Some silicone sealants (including most bathroom sealants) will eat through the paint.
January 21st, 2016, 2:51 am
Post Re: water
You have a special car window kit that stays soft. Are you sure it is coming from the windscreen and not from the air vent.
January 21st, 2016, 9:06 am
Post Re: water
Tbh - if it's leaking around the windscreen probably means the rust worm has already got at it so losing a little paint isn't going to make much difference.......I've not seen any issue with paint loss when I've used silicon sealant but then mines a shed and not concours.
January 21st, 2016, 10:46 pm
Post Re: water
I guess the leaking must come from both ;)
I'll try the bath sealant.
January 22nd, 2016, 12:44 am
Users browsing this forum: No registered users and 202 guests
