View unanswered posts | View active topics It is currently June 19th, 2026, 12:29 pm
Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 27, 28, 29, 30, 31, 32, 33 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
Bart wrote:
Sure you don't have a short cut in your wiring?? otherwise it could be very bad news, because the 2cvs witch goes on around 1 bar, which happens with really hot oil on idle or when it is too late...
Also (I suppose I should ask you) but sure you have enough oil in the engine? Once my dad complained about the light coming on and it appeared he had an almost empty sump :|
I'm pretty sure I have no short cut, but will try with a seperate lightbulb/wire directly to the + of the battery.
Oil is enough in the engine, theres a looking glas with marks at the left side of the engine....
November 10th, 2015, 12:37 am
a thicker oil may be neccesary?
November 10th, 2015, 9:08 am
lpgo wrote:
Biggest problem at the moment is........ I have no decent oilpressure in the BMW engine.. Connected the oilpressure switch to the Original 2cv light and it is going on and off all the time..... Bought already a newoilpressure switch wirh no better result........
Put gauge instead of pressure sensor. No need to guess by that way...
November 10th, 2015, 2:36 pm
Thinking about that too Jasu.... Thanks
November 10th, 2015, 7:50 pm
Have a caliper gauge lying here if you want to use it for a test?
November 10th, 2015, 7:59 pm
Almost ready for RDW.....
November 12th, 2015, 11:55 pm
nice, schoeffel goes with it to the RDW? :mrgreen:
November 13th, 2015, 6:12 pm
Yep, sjoeffel goes RDW.... :lol: I don.t think they give a fail for that... Can they??? :?
November 13th, 2015, 9:58 pm
Here it is in the "kirchröadsjer dieksiejoneer" the (very local) dialect dictionary.....
November 13th, 2015, 10:34 pm
Post Re: BMW 2cv engine conversion + Sjoefel
Loat dich door de RDW maar neet ondersjoefele.
( Don't let the RDW ( MOT) reject )
November 14th, 2015, 9:34 am
Users browsing this forum: No registered users and 226 guests
