View unanswered posts | View active topics It is currently June 19th, 2026, 12:45 pm
Reply to topic  [ 7 posts ]
 A-panel bracket - extended?
Post A-panel bracket - extended?
Hey guys,
Has anyone seen brackets for the A-panels that are longer than normal so there can be airflow out of the back of them as well? I've heard of them being manufactured but can't track any down.
regards,
fritz
October 20th, 2015, 11:11 am
Post Re: A-panel bracket - extended?
Do you mean the wing valence panel? (The A panel is the triangle between the A pillar, sill and bulkhead).
The lengthened quick release ones are made by VGS: http://www.vgs2cv.be/index.php/nl/webshopvgsvm/rallyraidshopnl/vleugelhaakjes-2cv-detail
You can fit them in standard position, or quick release them, turn them round and have the valence panel tilted out to let the heat out.
October 20th, 2015, 2:57 pm
AAAAhhhh you did look at my foto's ;) ;) ;) ;) ;) I fixed them with a little steelplate to the fender... I think this will give more airflow under the bonnet, however you may need to have little spoilers at the end of the a panels (otherwise the air curls to inside instet of sucking the air out).. I need to investigate that but it looks cool doesn't it.....
I'm doing this car (again) on a budget and 45 euro for the VGS ones is to much for me....
(I'm still Dutch you know....)
October 20th, 2015, 4:48 pm
45 euros is the whole budget of the car...;-)
October 21st, 2015, 5:32 pm
You are right... The body was 50 euro..
October 21st, 2015, 6:45 pm
I've just made ​​some longer .
Image 2cv special 0,6Tii
viewtopic.php?f=5&t=1610
October 24th, 2015, 7:06 am
I've seen these tilted valence panels before, very cool indeed 8-)
€45 though uuuurggghhh ! I'll try and make my own first!
Regards. Max.
October 25th, 2015, 7:25 pm
Users browsing this forum: No registered users and 216 guests
