View unanswered posts | View active topics It is currently February 3rd, 2026, 11:30 am
Reply to topic  [ 538 posts ]  Go to page Previous  1 ... 50, 51, 52, 53, 54  Next
 Joolz's Red One
Post Re: Joolz's Red One
Any luck?
Regards. Max.
August 19th, 2015, 11:39 am
I've been making progress. I've made up new gearbox mounts to fit the 4-sp back in, and it sits 40mm lower at the back than the 5-sp. The engine and box are back in, and some of the ancillaries are on, driveshafts connected, new outer 2cv and middle gaiter on the righthand side. There's been lots of having to wash parts down before refitting them, as everything's black with oil, including washing the brake pads with petrol and sanding the rust off discs. Huge amounts of clutch 'paste' to clean off the flywheel, and fitted a better secondhand friction plate.
Still got to modify the exhaust swan-neck so it fits, and then its mostly just reconnecting stuff. Also got to replace some fuel pipe too. There's a piece I fitted about 18 months ago that's full of cracks, despite it being date stamped 2013 and having 'R9 suitable for unleaded' written on it.
A couple more nice days would see it ready, but today's looking like being rained off, so still not sure.
There would be photos, but I'm having difficulty uploading them from the tablet, either directly or via photobucket.
August 19th, 2015, 12:39 pm
OK here you go. Extremely oily, but still manages to rust!
Out with the old, in with the... old!
New mounts, using part of the very first set, but now with the transit shock bushes welded on.
August 19th, 2015, 1:15 pm
Date stamped 2013, utter shite!
There's some other stuff that's only R6 and has been on there a couple of years longer and is still ok, but it's branded Codan, guess it pays to have a name on it.
August 19th, 2015, 6:11 pm
Eh jules a few questions if you have a bit of spare time
Got any more photos of the gearbox mount??
i like your thinking, i was considering using ZX lower arm front bushes x 2
did you shorten the Visa bell housing on this one, like you previously mentioned
and lastly i think it is a 2cv flywheel is it modified ( lightened)
cheers lou
August 19th, 2015, 10:08 pm
Lou, there are quite good pics of the mounts on the 5sp back on page 21, they're still the same now except the bracket on the gearbox is slightly different.
All my different incarnations of gearbox have used a visa bellhousing with 10mm machined off the front, the crank spacer is shorted to match, the flywheel has a few mm skimmed off the engine side for clearance.
August 19th, 2015, 11:55 pm
Was it cheap fuel hose? I find only marine outboard fuel hose lasts any length but its mega bucks
August 24th, 2015, 9:31 am
Looks like it's been too warm.....
August 24th, 2015, 11:43 am
Could have been warm, it was directly over the gearbox. Think it came from 'advanced fluid solutions' and was the cheapest stuff I could find that had a high enough spec (labeled R9). Will have to go for something superior in future, trouble is knowing what that is.
August 24th, 2015, 11:33 pm
Joolz,
how about the bend radius, assuming there was one?
( A minimum of 50mm for that size of fuel hose, iirc and since the crazing/cracking looks to be somewhat one-sided...)
August 25th, 2015, 12:14 am
Users browsing this forum: No registered users and 442 guests
