View unanswered posts | View active topics It is currently June 19th, 2026, 12:39 pm
 One for Ken!
Post One for Ken!
Funny one for you - runs fine on normal roads from start up and then the motorway for 2 hours at 70mph then as soon as I start doing some stop start driving and normal road speeds stutters on first application of accelerator - any ideas?
August 6th, 2015, 1:31 pm
Post Re: One for Ken!
Coil showing its age would be my first thought, especially if you're running an original ignition setup...
August 6th, 2015, 3:33 pm
Nope, new coil and electronic assist....
August 6th, 2015, 6:55 pm
Vapour lock in fuel hose.....
August 6th, 2015, 8:44 pm
Do you mean it's hot and so causing that?
August 7th, 2015, 12:25 am
Exactly.. Driving for long distance and then stop will cause a lot of heat building up in the engine bay which can heat up and vaporise the fuel in the carb which causes a lean spot for a momemt when driving on again....
August 7th, 2015, 6:32 am
I saw the same over here in Poland again and again at the gas stations... 2cv's which needed to start for more then 20 seconds befor they came alive after a refill when hot (driving on the motorway for hours and hours)... Luckely my engine started within the first turn of the key with 1-2-Spark and 1-2-Squirt). And no it's not an advertisement I just noticed it several times... Should have made a video of it so....
August 7th, 2015, 6:40 am
One of my friends had the above symptoms Geo and they went away when I re drilled primary, retarded the ignition a tad (123) and then fitted my spare high output coil
the coil made the biggest differance to the running, the jet and timing sorted the pinking/pinging/
August 7th, 2015, 5:30 pm
I'm still driving on the original 45 years old black coil going along with the original 45 years old car..I never felt the need to use another coil. Not even in my turbocar.....
Your coil is as good as you ignition system is...
August 7th, 2015, 8:33 pm
:idea: Even a new coil can be defective.
Try another one or cool it down with an ice bag.
:idea: Is the choke fully retracted?
I've Been Wrong Before.
August 18th, 2015, 7:30 pm
Users browsing this forum: No registered users and 228 guests
