View unanswered posts | View active topics It is currently June 19th, 2026, 4:53 pm
 Bolts
Online
Post Bolts
For those that have put 8mm bolts to hold the steering arm to the hub....
Socket bolts are easy to obtain but difficult to provide a secure locking method.
So......
https://www.westfieldfasteners.co.uk/BZ ... Rpart.html
Can supply M8 Hexagon head bolts which allows them to be locked with the locking tab.
August 3rd, 2015, 11:11 am
Post Re: Bolts
Nice find, that man... ;)
So......
August 6th, 2015, 3:36 pm
Online
Post Re: Bolts
@ Ken
Spoke to the company, bolts are imported, maybe EU or Far East.
So a thought...
How does one go about testing a 10.9 bolt?
August 6th, 2015, 4:01 pm
Post Re: Bolts
Cut a thread that's deep enough to engage the appropriate amount of thread (6 threads according to this site, but I'd go for 10mm depth http://www.gizmology.net/nutsbolts.htm ), then torque the bolt up with your torque wrench in stages until it shears?
Maybe put a couple of washers under the head to reduce frictional losses as well.
Using the info from this site, http://www.rpmmech.com/pdf/tightening_torque.pdf , a Class 10.9 M8 x1.25 bolt should be good for 36N.m, so a 50% overload would be 54 N.m.
I tested a couple of bolts from the box of 200 flywheel bolts I'd bought some years back and they survived that test, although they had been taken somewhat beyond the elastic limit... ;)
subarupete wrote:
@ Ken
So a thought...
August 6th, 2015, 7:53 pm
Post Re: Bolts
Would there realy be this high stress on these bolts... The steering arm is hold on its place already.. So the bolts are almost only tot secure it
August 6th, 2015, 8:48 pm
Online
Post Re: Bolts
Have come loose and broken a few off-roading, don't know about the Race cars others will have info.
August 6th, 2015, 9:35 pm
Post Re: Bolts
Have come loose may never occure when secured right...
August 6th, 2015, 10:00 pm
Post Re: Bolts
During the time that I spannered for the ECAS 2CV racing team, I recall that the security of those bolts was always checked if the car ever suffered an 'off'.
More often than not, you'd find that the bolt torque was lower than it should be, as a result of heavier side loading on the steering arms.
Hardly surprising, given that bolts are primarily designed to withstand tensile loading while clamping components together, not to resist shear...
August 6th, 2015, 11:53 pm
Post Re: Bolts
the bolts do get strained and ive seen the welded on arms crack the weld too during the 24hrs - M8 dont seem to cause any problems and mine, with no locking what so ever, have been fine despite making it to Salbris, Alacaniz and now Torun.
Nice site though, with a clever navigation ...now if only they did M10X1 in 10.9s :)
August 7th, 2015, 5:40 pm
Online
Post Re: Bolts
M10 x 1 where are you using those?.
August 7th, 2015, 6:27 pm
Users browsing this forum: No registered users and 191 guests
