View unanswered posts | View active topics It is currently April 28th, 2026, 6:24 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 49, 50, 51, 52, 53, 54, 55 ... 105  Next
 Make Your Own ....2CV.... 4x4
subarupete wrote:
@Jasu,
C5 front struts are a lot easier to find in the UK.
Yes, that's true. Lot easier to find, practically free to collect, but these rear cylinders are much easier to install -reason why I mentioned them...
About hydraulic connections, there is used two different threads. Bigger (M16*1,5 if remember correct) is used with Hydractive 3+ and smaller (M10*1) with H3. The bigger is some kind of easier, becouse it is common in "real hydraulic parts"...
August 5th, 2015, 12:45 pm
We should meet up sometime, Are you in NL?
Agree that the rear would easier to mount, as the pivot is part of the strut. Only saw one item on ebay @ £90 :( .
Also C6 (even harder to find) they have a Solenoid Valve in the strut, like the C5 centre sphere assembly.
Your are correct re the C5 Front Strut Tops.
I ended up with a mixture, earlier C5 have the M10, those with the extra centre sphere have the larger connections.
My Rear Strut Tops.
With the rear struts they have M16, but I managed to obtain the pipe with 2 end connections.
With "Tig weld" to std steel 3.5mm pipe union.
See
My Front Strut Top.
The fronts are M10 with a special connections, same as late Xantia.
Hard to DIY fabricate
UK supplier
See http://www.eurocarcare.net/hydraulics/e ... -rear.html.
These unions also fit the pump (BHI) .
August 5th, 2015, 1:34 pm
No, I live about middle of Finland. Meeting could be great, so let me know if you are coming here.
August 5th, 2015, 5:02 pm
Did the Raid PR in (Feb 09) organised by Vekku and Jukka, had a good time so may visit again
August 5th, 2015, 5:11 pm
Getting there....
Fill up with Hydraulic LDS oil, wire up the pump and solenoids...and then Test :?:
August 9th, 2015, 10:11 am
Looking great your solution...
However I have my doubts... As far as I can see it by the picture your point where the cilinder is attached to your arm is wrong... When your suspension compresses your arm
(force= arm x power) is getting smaller, so you will need (relative) more pressure to get your hight right.. it should be the other way round when your suspension compresses your arm must getting longer (or at least equal).. my opinion
Hope you understand what I'm trying to say.. That's also why your rear-end suddenly pops up (I guess)...
August 9th, 2015, 10:29 am
You're right (as always), but there's the problem with the axle being the other way around, and not enough room to mount things the way it works best.
Maybe the progressiveness of the spheres is just enough to overcome problems.
August 9th, 2015, 10:39 am
Wait and see.
August 9th, 2015, 11:17 am
Can't wait...... want to see... ;) ;)
August 9th, 2015, 11:30 am
Rear Suspension.
Rear "Pops Up" as the pivot goes thru its higest point.
August 9th, 2015, 11:32 am
