View unanswered posts | View active topics It is currently April 28th, 2026, 5:07 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 46, 47, 48, 49, 50, 51, 52 ... 105  Next
 Make Your Own ....2CV.... 4x4
@AZS Maybe it would be possible to mount 2 spheres in parallel?
The idea also may be worth looking at, however lot of lathe/mill machine work... I have a lathe..
Going to try an old Xantia sphere that was on UK ebay?
June 18th, 2015, 1:52 pm
subarupete wrote:
My understanding is LHM spheres (with Re-gass and Rebuild Valves) do not fit the C5 strut, but have a lead that a French guy has made an adapter?
All spheres fit, even the oldes LHS2 -spheres from -53 Traction fit to 2015 C5. The thread is same all of them...
And, LHM and LDS are full compatible, only LHS2 is total different. LHS2 uses EPDM and LHM/LDS NBR. That is the reason why you can't use pre -66 spheres or any hydraulic parts, unless you change all rubber parts to NBR...
Have been playing with these long enough, made refill -tools for old serviceable spheres to refill with the original plug (what is said it's impossible to refill). Also some experience with different gasket materials and hydraulic fluids...
You can adapt another sphere by using Hydractive central sphere unit, from Xantia VSX/Activa, Xm or C5 with Hydractive3+.
Also suitable "adapter" is quite easy to make fron Cx/Xm brake-sphere mounting piece. The small part under sphere. That "odd-looking" sphere is ld version of brake accumulator sphere, what is replaced on Cx that special-sphere what was used on Ds/Sm and some Maseratis also...
June 18th, 2015, 2:02 pm
@jasu
Like..
Good info
FYI
See pic of my first bracket, tried the pump, bracket badly aligned,not bolted up and bad welds....
Quite a bang....
June 18th, 2015, 2:12 pm
Measured Max and Min not the most extreme but happy with the result, with total of 20cm at the bumper.
Cut the engine covers and tried the seat, all seems to fit.
Need to postions pipe work and fasten down with clips.
Control Box with Up/Down buttons for each side
June 19th, 2015, 3:12 pm
Great job - why didn't you put the control buttons up near the steering wheel?
June 19th, 2015, 5:16 pm
Too many wires.....
So an old remote TX/RX control from the junk box....
Remote control from 50metres
June 19th, 2015, 6:05 pm
don't let Geo near your car...
he will interrupt the signal and "Snail it" low and slow with his wirless control... remember he can already hack your ignition ;)
June 22nd, 2015, 9:21 am
:D :D :D
ps The Snail forum http://www.snail2cv.com/ has vanished?
June 22nd, 2015, 9:45 am
Ofcourse I can.. NOT :D :D :D :D
June 22nd, 2015, 12:07 pm
subarupete wrote:
:D :D :D
German 2cv forum is also gone: http://www.2cvforum.de//
(I know I know no pain in the ar... :lol: :lol: :lol: )
June 22nd, 2015, 12:10 pm
